[fusion-dev] fusion and projection support
Mike Adair madair at dmsolutions.ca
Tue Oct 6 14:08:35 EDT 2009
That change is required so that the Measure widget can work with maps in
various projections, otherwise the distances measured don't make sense
at all (for both MapServer and MapGuide).
I don't see how that revision would break a MapGuide application,
perhaps you can explain?
I am working on a patch for MapGuide side of things to set the
projection automatically. Ideally the MapGuide API would have a way of
returning the EPSG code for a map and indeed it does have
$csFactory->ConvertWktToEpsgCode($srs), however I am getting an error
whenever I try to use that "Could not convert to EPSG code from WKT". It
is for this reason that I put support for that in the Map extension
element in AppDef. If you can point to a better way of informing the
client about the EPSG code for the map I would be happy to hear it.
Mike
Andreas Morf wrote:
> With rev. 1907 Mike added projection support to fusion – this screwed
> up my fusion app where I use projected coordinates (swiss grid): the
> oMapOL was set to default value EPSG:4326 which was the source of
> malfunction.
> I normally set the CRS in my MG-mapdefinition and I don’t want to set
> it again in fusion and additionally provide a EPSGxy.js (). Shouldn’t
> fusion read out CRS-def from MG-server mapdef for the actual map and
> use that for client-side calculations?
> IMHO 1907 looks a bit like a quick and dirty fix for mapserver
> concerns – the whole matter shoud be discussed an planned from ground
> up (RFC?).
> Greets, Andreas
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-dev mailing list
