[fusion-dev] Recursion issue? with the legend updates
Zac Spitzer zac.spitzer at gmail.com
Wed Jul 14 04:06:25 EDT 2010
I am working thru an issue with a map i have, using the mapguide 2.2 beta
at the moment.
Basically when i drop below the scale of 20k, the browser will lock up
for upwards
of 35-60 seconds in the update legend.js code.
So far after some profiling pain, i have worked out that commenting out the
line below stops the problem
    _update: function() {
            //this.updateGroupLayers(map.layerRoot.groups[i], currentScale);
I will continue my digging to see if I can work out what is causing the issue.
Looks like some kind of nasty recursion or something
Thought I'd touch base to see if anyone else has seen this
regards
z
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-dev mailing list
