[fusion-dev] Re: [Code Review]: Print widget doesn't work with IIS7
Paul Deschamps pdeschamps at dmsolutions.ca
Tue Mar 30 23:27:11 EDT 2010
I think what you are looking for is here:
http://support.microsoft.com/kb/819267
Cheers
Paul D.
On Tue, Mar 30, 2010 at 5:05 PM, Kori Maleski <kori.maleski at gmail.com> wrote:
> On line 59 of Print.js:
> Change
> this.dialogContentURL = Fusion.getFusionURL() + widgetTag.location +
> 'Print/Print.html';
> to
> 'Print/Print.php';
> Rename the file Print.html to Print.php (change the extension)
> That may work.  IIS7 has an issue with GETs vs POSTs when utilizing html
> pages.
> Cheers,
> Kori Maleski
> On Tue, Mar 30, 2010 at 5:53 AM, TJmapper <tjordan at ddcwsa.com> wrote:
>> I have an install of Mapguide Enterprise 2010 and I tried this code to no
>> avail. My print dialog comes up blank still and i get a 404 error instead
>> of
>> a 400. Mine is still looking for the Print/Print.HTML I believe.
>> Are there any other tricks with the Print.js I should try? Maybe there is
>> something i am missing, but i can completely remove the Print.js file and
>> it
>> comes up with the same error. Does the Enterprise version read from some
>> place else?
>> I have been struggling with this for a few days now.
>> Thanks.
>> View this message in context:
>> http://n2.nabble.com/Code-Review-Print-widget-doesn-t-work-with-IIS7-tp4150860p4824288.html
>> Sent from the Fusion Developers mailing list archive at Nabble.com.
>> fusion-dev mailing list
>> fusion-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-dev
    Paul Deschamps
    Applications Specialist
    DM Solutions Group Inc.
    Office: (613) 565-5056 x28
    http://www.dmsolutions.ca
    http://research.dmsolutions.ca
More information about the fusion-dev mailing list
