[fusion-dev] Re: [Code Review]: Print widget doesn't work with IIS7
TJmapper tjordan at ddcwsa.com
Wed Mar 31 08:18:49 EDT 2010
Thank you for your help. My print widget works, but i have another question.
I had to edit a file called fusionSF-compressed.js to get this to work, not
Print.js. I am assuming this is an autodesk thing? Like i said i installed
using Mapguide Enterprise 2010. My issue is that this js file is just 1 long
line of text almost 700k characters long. Is there a compiler or something i
am missing? Im not nearly as fluent in the code as most of you guys so i
appreciate your patience.
Thanks again.
View this message in context: http://n2.nabble.com/Code-Review-Print-widget-doesn-t-work-with-IIS7-tp4150860p4830452.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
