[fusion-dev] Re: [Code Review]: Print widget doesn't work with IIS7
Mike Adair madair at dmsolutions.ca
Wed Mar 31 12:23:28 EDT 2010
That is the compressed and single file version of Fusion (which can be
re-created using the Ant build script build.xml
http://trac.osgeo.org/fusion/wiki/ANTBuildSystem).  That file is useful
for a production site, but for debugging and developing, it is easier to
just load fusion.js in place of fusionSF-compressed.js - that will pull
in all the other files required.  That way you can modify the individual
files and then you can create the compressed single file build to
optimize performance.
Mike
TJmapper wrote:
> Thank you for your help. My print widget works, but i have another question.
> I had to edit a file called fusionSF-compressed.js to get this to work, not
> Print.js. I am assuming this is an autodesk thing? Like i said i installed
> using Mapguide Enterprise 2010. My issue is that this js file is just 1 long
> line of text almost 700k characters long. Is there a compiler or something i
> am missing? Im not nearly as fluent in the code as most of you guys so i
> appreciate your patience.
> Thanks again.
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
More information about the fusion-dev mailing list
