[fusion-dev] Re: [Code Review]: Print widget doesn't work with IIS7
TJmapper tjordan at ddcwsa.com
Wed Mar 31 12:27:04 EDT 2010
Thank you sire. That is very helpful.
  From:       "Mike Adair [via OSGeo.org]" <ml-node+4831864-1713143333-279955 at n2.nabble.com>
  To:         TJmapper <tjordan at ddcwsa.com>
  Date:       03/31/2010 12:23 PM
  Subject:    Re: [Code Review]: Print widget doesn't work with IIS7
That is the compressed and single file version of Fusion (which can be
re-created using the Ant build script build.xml
http://trac.osgeo.org/fusion/wiki/ANTBuildSystem).  That file is useful
for a production site, but for debugging and developing, it is easier to
just load fusion.js in place of fusionSF-compressed.js - that will pull
in all the other files required.  That way you can modify the individual
files and then you can create the compressed single file build to
optimize performance.
Mike
TJmapper wrote:
> Thank you for your help. My print widget works, but i have another
question.
> I had to edit a file called fusionSF-compressed.js to get this to work,
not
> Print.js. I am assuming this is an autodesk thing? Like i said i
installed
> using Mapguide Enterprise 2010. My issue is that this js file is just 1
long
> line of text almost 700k characters long. Is there a compiler or
something i
> am missing? Im not nearly as fluent in the code as most of you guys so i
> appreciate your patience.
> Thanks again.
   Michael Adair
   Senior Software Architect
   DM Solutions Group Inc.
   Office: (613) 565-5056 x26
   [hidden email]
   http://www.dmsolutions.ca
   http://research.dmsolutions.ca
fusion-dev mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/fusion-dev
View message @
http://n2.nabble.com/Code-Review-Print-widget-doesn-t-work-with-IIS7-tp4150860p4831864.html
To unsubscribe from Re: [Code Review]: Print widget doesn't work with IIS7,
click here.
View this message in context: http://n2.nabble.com/Code-Review-Print-widget-doesn-t-work-with-IIS7-tp4150860p4831884.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
