[fusion-dev] Please review the patch: enhance the MapTip widget to enable/disable map tooltips
Buddy Hu Buddy.Hu at autodesk.com
Sun Jul 31 21:58:20 EDT 2011
Thanks Mike,
Thanks for your comments!
1.       The default behavior is not break, this button is enabled by default.
2.       About this.mainPath, I intended to get the template directory. I will use Fusion.getApplicationURL() to replace this code snippet.
Regards,
Buddy
From: fusion-dev-bounces at lists.osgeo.org [mailto:fusion-dev-bounces at lists.osgeo.org] On Behalf Of Michael Adair
Sent: Saturday, July 30, 2011 1:05 AM
To: fusion-dev at lists.osgeo.org
Subject: Re: [fusion-dev] Please review the patch: enhance the MapTip widget to enable/disable map tooltips
Hi Buddy,
I have a couple of comments on this:
1. the default behaviour should remain the same as before applying this patch which is to be enabled without a button.  To me it looks like you are changing this widget to always require a button to enable the tooltips, which will break a lot of existing applications that don't have a spot for the button.   You need to make the button an optional behaviour.
2. calculating this.mainPath: we already have Fusion.fusionURL which holds a pointer to where fusion.js was loaded from and your images should be relative to that or relative to the template directory.  The way you are getting that image URL just looks odd to me and not the usual Fusion way of doing things.
Cheers,
Mike
On 29/07/2011 5:35 AM, Buddy Hu wrote:
Hi List,
Please help to review the patch: https://trac.osgeo.org/fusion/ticket/471
This patch intends to enhance the "MapTip" widget, makes this widget to be a UI widget(a button), so that the users can press it to enable/disable the map tooltips.
The motivation of this enhancement is to provide an opportunity for the users to reduce the overload of Server by disable the map tooltips.
Thanks in advance!
Buddy
fusion-dev mailing list
fusion-dev at lists.osgeo.org<mailto:fusion-dev at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/fusion-dev
URL: http://lists.osgeo.org/pipermail/fusion-dev/attachments/20110801/cb517fde/attachment.html
More information about the fusion-dev mailing list
