[fusion-dev] Re: Adding WMS in Application Definition
Zac Spitzer zac.spitzer at gmail.com
Tue Jun 28 23:08:38 EDT 2011
can you post your xml?
if you can't share your provider information, try with a public source
http://onearth.jpl.nasa.gov/tiled.html
using firebug, there's no errors in the console or failed requests in
the net panel
On Wed, Jun 29, 2011 at 7:06 AM, ggdm <giudim86 at libero.it> wrote:
> Yes, I can see the <div id="OpenLayers.Layer.WMS_8"> but it's empty, there's
> no html code inside it.
> Maybe I'm doing something wrong in the xml.
> Could You post a brief example showing how to add a public wms server in
> application definition xml?
> Thank You very much for your interest, as this could be a killer improvment
> in speed for me...
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-WMS-in-Application-Definition-tp6514397p6526633.html
> Sent from the Fusion Developers mailing list archive at Nabble.com.
> fusion-dev mailing list
> fusion-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-dev
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
More information about the fusion-dev mailing list
