[fusion-dev] Re: Adding WMS in Application Definition
ggdm giudim86 at libero.it
Wed Jun 29 03:26:36 EDT 2011
I tried but no luck as before.
I'm posting my mapgroup xml here:
/<?xml version="1.0" encoding="utf-8"?>
<MapSet xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema">
  <MapGroupType id="Map">
    <Map>
      <Type>MapGuide</Type>
      <SingleTile>true</SingleTile>
      <Extension>
        <ResourceId>Library://Map.MapDefinition</ResourceId>
        <SelectionAsOverlay>true</SelectionAsOverlay>
        <SelectionColor>0x0000FFA0</SelectionColor>
        <ImageFormat>PNG</ImageFormat>
        <Options>
          <isBaseLayer>false</isBaseLayer>
          <userOverlay>true</userOverlay>
          <projection>EPSG:900913</projection>
        </Options>
      </Extension>
    </Map>
    <Map>
      <Type>WMS</Type>
      <SingleTile>false</SingleTile>
      <Extension>
        <ResourceId>http://onearth.jpl.nasa.gov/wms.cgi?</ResourceId>
        <Options>
          <name>NASA</name>
        </Options>
        <Parameters>
          <layers>global_mosaic</layers>
        </Parameters>
      </Extension>
    </Map>
    <Map>
      <Type>Google</Type>
      <Extension>
        <ResourceId>Google</ResourceId>
        <Options>
          <name>Google Maps Street</name>
          <type>G_NORMAL_MAP</type>
        </Options>
      </Extension>
    </Map>
    <Extension />
  </MapGroupType>
</MapSet>
BTW I'm using Infrastructure Map Server 2012
Thanks again
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-WMS-in-Application-Definition-tp6514397p6527980.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
