[fusion-dev] Open fusion viewer using PHP
Jackie Ng jumpinjackie at gmail.com
Tue Sep 15 19:24:47 PDT 2015
Yes you have to pass down the ApplicationDefinition id as well, otherwise the
template will default to loading the ApplicationDefinition.xml located in
the template's root directory.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Open-fusion-viewer-using-PHP-tp5223941p5224374.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
