[fusion-dev] Open fusion viewer using PHP
Jackie Ng jumpinjackie at gmail.com
Wed Sep 16 23:23:55 PDT 2015
The search widget does not currently support showing search results on the
map, if that is your question.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Open-fusion-viewer-using-PHP-tp5223941p5224573.html
Sent from the Fusion Developers mailing list archive at Nabble.com.
More information about the fusion-dev mailing list
