[fusion-trac] #195: Request.QueryString Returns Null or Nothing Parameters
Fusion trac_fusion at osgeo.org
Wed Dec 17 13:13:17 EST 2008
   Reporter:  bberdel  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  2.0
  Component:  Core     |     Version:  1.1.0
   Severity:  Major    |    Keywords:  parameter querystring
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 In all previous versions of Fusion (before 1.1) I was able to use
 request.querystring from the task frame to return parameters such as
 MapName and SessionID.   However this no returns an empty list and there
 are no paramaters.  I have also tried the code below.
 NameValueCollection parameters;
 if(Request.HttpMethod == "POST")
     parameters = Request.Form;
 else
     parameters = Request.QueryString;
 String mapName = GetParameter(parameters, "MAPNAME"); String session =
 GetParameter(parameters, "SESSION");
 _____________________________________________________________
 Where the GetParameter method looks like this:
 String GetParameter(NameValueCollection parameters, String name) {
     String strval = parameters[name];
     if (null == strval)
         return "";
     return strval.Trim();
Ticket URL: <http://trac.osgeo.org/fusion/ticket/195>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
