[fusion-trac] #195: Request.QueryString Returns Null or Nothing
Parameters
Fusion
trac_fusion at osgeo.org
Wed Dec 17 18:28:23 EST 2008
#195: Request.QueryString Returns Null or Nothing Parameters
Reporter: bberdel | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Core | Version: 1.1.0
Severity: Major | Resolution:
Keywords: parameter querystring | External_id:
State: New | Browser: All
Os: All |
Comment (by chrisclaydon):
I'm seeing the same problem with MGE 2009 Update 1 using the .NET web
tier. It looks like the MAPNAME and SESSION parameters are sent twice as
URL request parameters when the target is the task pane. That causes my
particular script to fail. But if I set the target to be a new window, it
succeeds. In this case, the parameters only show up in the URL request
once.
If you set your target to be a new window, does it work for you?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/195#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
