[fusion-trac] #195: Request.QueryString Returns Null or Nothing Parameters
Fusion trac_fusion at osgeo.org
Wed Dec 17 18:47:15 EST 2008
 Reporter:  bberdel                |         Owner:  madair
     Type:  defect                 |        Status:  new
 Priority:  P2                     |     Milestone:  2.0
Component:  Core                   |       Version:  1.1.0
 Severity:  Major                  |    Resolution:
 Keywords:  parameter querystring  |   External_id:
    State:  New                    |       Browser:  All
       Os:  All                    |
Comment (by chrisclaydon):
 I changed the execute method in InvokeURL.js to this, and it fixed the
 problem. It doesn't add the extra params when the target is the task pane,
 since the setContent() method adds them anyway:
     execute : function() {
         var url = this.sBaseUrl;
         //add in other parameters to the url here
         var map = this.getMap();
         var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
         var params = [];
         if ( taskPaneTarget == null ) {
             params.push('LOCALE='+Fusion.locale);
             params.push('SESSION='+map.getSessionID());
             params.push('MAPNAME='+map.getMapName());
         params = params.concat(this.additionalParameters);
         if (url.indexOf('?') < 0) {
             url += '?';
         } else if (url.slice(-1) != '&') {
             url += '&';
         url += params.join('&');
         if ( taskPaneTarget ) {
             taskPaneTarget.setContent(url);
         } else {
             var pageElement = $(this.sTarget);
             if ( pageElement ) {
                 pageElement.src = url;
             } else {
                 window.open(url, this.sTarget, this.sWinFeatures);
Ticket URL: <http://trac.osgeo.org/fusion/ticket/195#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
