[fusion-trac] #89: Search panel: incorrect parameters javascript calls
Fusion
trac_fusion at osgeo.org
Tue Jul 15 08:17:13 EDT 2008
Reporter: pagameba | Owner: madair at dmsolutions.ca
Type: defect | Status: new
Priority: P2 | Milestone: 1.0.7
Component: Widgets | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: Approved
Browser: All | Os: All
Reported by Rémy, filed in mapguide trac as:
http://trac.osgeo.org/mapguide/ticket/630
This appears to be a copy/paste error when we brought the search panel
over, to be fixed in 1.0 and trunk.
I found a fix that worked.
First, looking at widgets/Search/Search.templ:
function CellClicked(sel)
var map = GetParent().Fusion.getMapByName(mapName);
map.setSelection(sel, false, true);
Should be changed like this to match correctly the API:
map.setSelection(sel, true);
Second, the call to setSelection from map object is (lib/Map.js):
setSelection: function(selText, requery, zoomTo) {
for (var i=0; i<this.aMaps.length; i++ ) {
this.aMaps[i].setSelection(selText, requery, zoomTo);
setSelection: function(selText, zoomTo) {
this.aMaps[i].setSelection(selText, zoomTo);
Finally, setSelection from Mapguide.js has for params:
'selection': encodeURIComponent(selText),
it's proposed to change like this:
'selection': selText,
encodeURIComponent encodes twice the params and that make the call-back
error happend.
We see that setSelection has finally in Mapguide.js only 2 parameters:
selText, zoomTo.
But in Map.js and Search.templ it was called with 3 parameters: selText,
requery, zoomTo
Quite confusing for a mistake.
Rémy
Ticket URL: <http://trac.osgeo.org/fusion/ticket/89>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
