[fusion-trac] #88: Follow-Up: Repeated authentication dialogs
Fusion
trac_fusion at osgeo.org
Fri Jul 11 10:10:15 EDT 2008
Reporter: jfournier | Owner: madair
Type: task | Status: new
Priority: P2 | Milestone: 1.1
Component: Core | Version: 1.0.6
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Subject: [fusion-users] Repeated authentication dialogs
I think I have worked out why sometimes fusion throws a lot of http
If you access a mapguide map as the Anonymous user and then jump
across to the webtier tests
and try something which prompts for authentication, all the map
requests then throw
an authentication dialog which with a tiled map will be quite a few.....
z
Zac Spitzer
Ticket URL: <http://trac.osgeo.org/fusion/ticket/88>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
