[fusion-trac] #121: Regression: Selection in an MGE Flexible
Web Layout fails if a raster layer is visible and selectable
Fusion
trac_fusion at osgeo.org
Tue Nov 4 17:46:12 EST 2008
#121: Regression: Selection in an MGE Flexible Web Layout fails if a raster layer
Reporter: davewilson | Owner: madair
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: MapGuide | Version: 1.0.7
Severity: Major | Resolution:
Keywords: | External_id:
State: Analysing | Browser: All
Os: Windows |
Comment (by davewilson):
I suspect this was a connection pooling problem that has been fixed with
the addition of Raster connection pooling in SP1. Although there is the
possibility that the error is related to a raster image that uses a
connection to a file or folder rather than uploaded. When the map has just
the raster layer and the same map is used in overview map in the layout
you should get an error when attempting to select by dragging a rectangle.
You should previously have some Montana data supplied a while back that
should work for this. I don't want to try and upload a large attachment as
we had issues with this before.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/121#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
