[fusion-trac] #149: Legend does not refresh map when layers
switched on/off when using selection overlay
Fusion
trac_fusion at osgeo.org
Wed Nov 5 09:38:13 EST 2008
#149: Legend does not refresh map when layers switched on/off when using
selection overlay
Reporter: chrisclaydon | Owner: pagameba
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1152221
State: Analysing | Browser: All
Os: All |
Comment (by pagameba):
(In [1636]) Re #149. Separate logic for drawing selection and map in the
case of a separate overlay layer in MapGuide. Also remove the resize
effect on the selection overlay layer as it causes a temporary visual
displacement of the selection image that is quite disconcerting.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/149#comment:4>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
