[fusion-trac] #254: Maptip opened URL default should be WITH scrollbars
Fusion trac_fusion at osgeo.org
Tue Jun 30 07:13:13 EDT 2009
 Reporter:  amorsell  |         Owner:  madair
     Type:  defect    |        Status:  new
 Priority:  P3        |     Milestone:  2.0
Component:  Widgets   |       Version:  1.1.1
 Severity:  Minor     |    Resolution:
 Keywords:            |   External_id:
    State:  New       |       Browser:  All
       Os:  All       |
Comment (by mbeckman):
 I think we can make all new weblayouts have scrollbars by default for
 maptip windows if we make a change in MapTip.xml. Unfortunately the
 setting that turns off scrollbars is saved in the weblayout xml so it
 won't change the behavior for existing weblayouts.
 IN maptip.xml change
   <Parameter>
     <Name>WinFeatures</Name>
     <Label>Window Features</Label>
     <Type>String</Type>
     <Description>Options for opening hyperlinks new window, if
 used</Description>
     <IsMandatory>false</IsMandatory>
 <DefaultValue>menubar=no,location=no,resizable=no,status=no</DefaultValue>
   </Parameter>
 TO
   <Parameter>
     <Type>String</Type>
 used</Description>
     <DefaultValue>menubar=no,location=no,resizable=no,status=no,
 scrollbars=yes</DefaultValue>
   </Parameter>
Ticket URL: <http://trac.osgeo.org/fusion/ticket/254#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
