[fusion-trac] #299: List of External Provider widget is not updated per Map.
Fusion trac_fusion at osgeo.org
Thu Sep 24 05:47:34 EDT 2009
   Reporter:  jennyhe  |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  1.1.1
   Severity:  Major    |    Keywords:
External_id:  1257713  |       State:  New
    Browser:  All      |          Os:  All
 Steps:
 From Autodesk QA
 1. New one flexible web layout with 2 maps.
 2. Select different base layer for each map.
 3. Save flexible web layout.
 4. Open it in IE.
 5. Switch Map.
 Results:
 After switching to another map, the list of external provider keeps the
 one of the default map.
 Expected results:
 The list of External Provider should be consistent with ones selected for
 maps.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/299>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
