[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Sun Nov 13 21:26:16 EST 2011
   Reporter:  christinebao  |       Owner:  Michael Adair <madair@…>
       Type:  defect        |      Status:  new
   Priority:  P2            |   Milestone:  Future
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
 Report from Autodesk QA:[[BR]]
 Step:[[BR]]
 1. Create SDF layer and add both dynamic and base layer into the map[[BR]]
 2. Create FWL and set Bing map as commerial layer[[BR]]
 3. Preview FWL[[BR]]
 Result:[[BR]]
 Dynamic layer and Base map does not match with each other (see attached
 dismatch.png)[[BR]]
 Expectation:[[BR]]
 The base map layer should be the same as the Dynamic layers when
 displaying in Bing map.[[BR]]
 Comments:[[BR]]
 It shows OK for other commerial layers.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
