[fusion-trac] #485: [Redline] Select function can't zoom to the correct object
Fusion trac_fusion at osgeo.org
Mon Nov 21 12:08:31 EST 2011
 Reporter:  liuar    |         Owner:  madair
     Type:  defect   |        Status:  closed
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  2.0
 Severity:  Major    |    Resolution:  fixed
 Keywords:           |   External_id:  1431481
    State:  New      |       Browser:  All
       Os:  All      |
Changes (by madair):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 fixed at rev [2464]
 this is default behaviour for OpenLayers but we can put an override so
 that the Map object will check the 'displayOutsideMaxExtent' setting from
 the baseLayer object to allow zooming outside maxExtent
Ticket URL: <http://trac.osgeo.org/fusion/ticket/485#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
