[fusion-trac] #486: Base map layers show in wrong places
working with Bing Maps
Fusion
trac_fusion at osgeo.org
Tue Nov 22 15:26:41 EST 2011
#486: Base map layers show in wrong places working with Bing Maps
Reporter: christinebao | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.3
Component: MapGuide | Version: 2.0
Severity: Critical | Keywords:
External_id: 1432080 | State: New
Browser: All | Os: All
Comment(by madair):
I'm still getting an error:
An exception occurred in DB XML component. Error: The specified schema
file is not found: C:\Program
Files\OSGeo\MapGuide\Server\Schema\LayerDefinition-2.3.0.xsd File:
c:\builds\mg22win32\mgdev\server\src\services\resource\XmlSchemaResolver.cpp
Line: 118
The highest version number in that directory for LayerDefinition.xsd that
I have is 1.3.0.
However, I was able to unzip the package and import the data and create a
layer from it using MG Maestro3.5 and add it to a sheboygan mercator map
and the streets all line up perfectly. I'm guessing there is somethign
wrong with you layer and/or map definition in terms of coordinate systems
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:8>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
