[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Tue Nov 22 22:34:03 EST 2011
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  assigned
   Priority:  P2            |   Milestone:  2.3
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
Comment(by christinebao):
 Hi Mike,
    LayerDefinition-2.3.0.xsd is added by r5168 on September 21, 2010, and
 actually it's not the latest one now. The latest LayerDefinition-2.4.0.xsd
 is in the repository also. If you sync
 http://svn.osgeo.org/mapguide/trunk/MgDev you will be able to load the
 packages. In this case we are on the same page.
    Anyway, I tried to modify layer definition in the package and made one
 with LayerDefinition 1.3. Please see attached
 http://trac.osgeo.org/fusion/attachment/ticket/486/1432080_LD1.3.mgp. It
 can still reproduce the problem.
    The detail steps of reproducing the problem if you want to load data by
 yourself:
    1. Load the attached
 http://trac.osgeo.org/fusion/attachment/ticket/486/CENTLINES.FeatureSource_DATA_CENTLINES.sdf.
    2. Create map, set coordinate system to WGS84.PseudoMercator (WGS84
 based Mercator (spherical formulation))
    3. Add both normal layer and base layer to this map. Base layer scale
 list is:
                                                            1128.497220,
                                                            2256.994440,
                                                            4513.988880,
                                                            9027.977761,
                                                            18055.955520,
                                                            36111.911040,
                                                            72223.822090,
                                                            144447.644200,
                                                            288895.288400,
                                                            577790.576700,
                                                            1155581.153000,
                                                            2311162.307000,
                                                            4622324.614000,
                                                            9244649.227000,
 18489298.450000,
 36978596.910000,
 73957193.820000,
 147914387.600000,
 295828775.300000,
 591657550.500000,
    4. Create flexible web layout, add commercial layer of Bing Map.
    5. Preview and you can see the problem.
 Please contact me if you have any question.
 Regards,
 Christine
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:9>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
