[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Thu Nov 24 22:14:04 EST 2011
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  assigned
   Priority:  P2            |   Milestone:  2.3
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
Comment(by christinebao):
 Hi Mike,
    Yes, our build is based on http://svn.osgeo.org/fusion/trunk and we
 have r2439 already, which is to support commercial layers with tiled map.
 Without this submission other commercial layers except bing maps cannot
 work with tiled map.
    So we have the same fusion and for unknown reason the Bing map does not
 work. You only work with fusion reminds me something. How do you use
 MapGuide? Install open source or build by yourself? Do you use standard
 template, can you test MapGuide template such as Slate?
    Do you have any suggestion to make us closer in this problem?
 Thanks & regards,
 Christine
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:13>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
