[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Fri Nov 25 10:23:32 EST 2011
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  assigned
   Priority:  P2            |   Milestone:  2.3
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
Comment(by madair):
 Christine,
 I typically load fusion pages on their own pointing to an AppDef, however
 I also tested this using the 'preview' button of Maestro 3.5
 I think the options at this point are:
 - you can set up a web site that I can see that demonstrates the problem,
 - and/or attach the tempalte and AppDef file that you are using (I already
 have the mgp package for the map)
 One thing to check since it's Bing maps only, are you including the bing
 script tag in the template? i.e.
 <script
 src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1'></script>
 update Fusions copy of the Openlayers lib perhaps?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:14>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
