[fusion-trac] #486: Base map layers show in wrong places working with Bing Maps
Fusion trac_fusion at osgeo.org
Mon Nov 28 03:49:44 EST 2011
   Reporter:  christinebao  |       Owner:  madair
       Type:  defect        |      Status:  assigned
   Priority:  P2            |   Milestone:  2.3
  Component:  MapGuide      |     Version:  2.0
   Severity:  Critical      |    Keywords:
External_id:  1432080       |       State:  New
    Browser:  All           |          Os:  All
Comment(by jng):
 Just to add a data point here.
 I can see the same problem, but I found an interesting observation. The
 scale of the map for some reason is off by a bit, so the mismatched layer
 is probably a rendering request for the finite scale range below it.
 See attached image
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:16>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
