[fusion-trac] #486: Base map layers show in wrong places
working with Bing Maps
Fusion
trac_fusion at osgeo.org
Mon Nov 28 22:13:13 EST 2011
#486: Base map layers show in wrong places working with Bing Maps
Reporter: christinebao | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.3
Component: MapGuide | Version: 2.0
Severity: Critical | Keywords:
External_id: 1432080 | State: New
Browser: All | Os: All
Comment(by christinebao):
Hi Jng,
Thank you very much to find out the problem of this ticket. Yes, the
offset is caused by scale 591657550.500000. The scales are set by Studio
automatically. We use the full set scale, which is Google layer scale:
1128.497220, 2256.994440, 4513.988880, 9027.977761, 18055.955520,
36111.911040, 72223.822090, 144447.644200, 288895.288400, 577790.576700,
1155581.153000, 2311162.307000, 4622324.614000, 9244649.227000,
18489298.450000, 36978596.910000, 73957193.820000, 147914387.600000,
295828775.300000, 591657550.500000.[[BR]]
There are total 20 scale in Google layer, and Bing map/Yahoo map/Open
street map are subset of Google layer, so we use the full set.[[BR]]
As I remember MapGuide tiled map is treated as overlay on commercial
layers. So I think MapGuide tiled map should find out which is current
commercial layers scale and show the one matches. If MapGuide titled map
has more than the commercial layers have, it should ignore those cannot
find matching scale. However the behavior of Bing map seems that it's hard
coded by offset, not decided by scale value, is it?
Anyway, it's glad to know the reason of this ticket. Let's find out a
solution to fix it.
Thanks & regards,
Christine
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:20>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
