[fusion-users] MapGroups - Multiple Maps?
Jason Birch Jason.Birch at nanaimo.ca
Thu Apr 17 11:11:33 EDT 2008
Thanks Mike
You could also set username and password parameters on each request
which, as long as you're using Basic without SSL, isn't much less
secure.
Good to hear that this kind of map grouping is on the radar.  It would
be cool if, for MapGuide, you could determine at load time whether the
map definition contains one or more tile groups and automatically create
the additional layers.
Jason
-----Original Message-----
Subject: Re: [fusion-users] MapGroups - Multiple Maps?
Fusion doesn't currently support combining different maps like that in
one MapGroup element so for the moment, you can only use one Map at a
time. However this is something I am currently working on, including
allowing other layer types supported by OpenLayers as the intent of the
MapGroup element is to be extended as you suggest.
I'm not sure about the username/password issue but it should be possible
to send along some Basic authentication headers along with the request.
More information about the fusion-users mailing list
