[fusion-users] MapGroups - Multiple Maps?
Mike Adair madair at dmsolutions.ca
Thu Apr 17 09:49:33 EDT 2008
Jason,
Fusion doesn't currently support combining different maps like that in
one MapGroup element so for the moment, you can only use one Map at a
time. However this is something I am currently working on, including
allowing other layer types supported by OpenLayers as the intent of the
MapGroup element is to be extended as you suggest.
I'm not sure about the username/password issue but it should be possible
to send along some Basic authentication headers along with the request.
Mike
Jason Birch wrote:
> Hi all,
> I'm trying to figure out how to replicate the tiled/untiled combination
> maps that MapGuide allows.  Fusion appears to only allow setting
> single-tiled or not for any map, so I'm guessing that I can't just point
> at a MapGuide map that contains both static and tiled layers.  I'm
> thinking that I need to define these maps using two maps inside of one
> group.  Something like:
>     <MapGroup id="Default" xsi:type="MapType">
>      <Map xsi:type="MapGuideLayerType">
>         <Type>MapGuide</Type>
>         <SingleTile>true</SingleTile>
>         <Extension>
> <ResourceId>Library://Nanaimo/NanaimoMap/Maps/Themes/Default.MapDefiniti
> on</ResourceId>
>         </Extension>
>       </Map>
>         <SingleTile>false</SingleTile>
>         <Extension>
> <ResourceId>Library://Nanaimo/NanaimoMap/Maps/Ortho_background.MapDefini
> tion</ResourceId>
>         </Extension>
>       </Map>
>     </MapGroup>
> Does this seem correct?  It doesn't appear to work for me; I see lots of
> requests but the map remains blank.
> Also, when attempting to access a tiled map, it is prompting me to enter
> a username/password.  Is there a configuration parameter I can use so
> that a fixed userid is used for these tiles?
> Thanks,
> Jason
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
