[fusion-users] Nested JxSplitters which don't want to work
kde kdelcroix at celsius-tech.com
Fri Dec 12 11:29:18 EST 2008
Here is the current page :
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
"http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<title>Test</title>
<meta http-equiv="Content-type" content="text/html; charset=utf-8">
<script type="text/javascript" src="../../../lib/fusion.js"></script>
<script type="text/javascript">
var main;
window.onload = function() {
  main = new Jx.Layout('AppContainer', {
         top: 2
  var sa1 = new Jx.Layout('SplitterArea', {
         left: 2,
         right: 2,
         top: 2,
         bottom: 2
  /* SPLITTER 1 */
  var splitter = new Jx.Splitter('SplitterArea',
								 elements: [$('Si'), $('SplitterArea2')],
                                 layout:'horizontal',
								 containerOptions: [{width: 200}]
  /* SPLITTER 2 */
  var splitter2 = new Jx.Splitter('SplitterArea2',
                                 elements:[$('Ma'), $('De')],
                                 layout:'vertical',
								 containerOptions: [{height: 200}, {height: auto}]
  main.resize();
</script>
<style type="text/css">
@import url(css/jxskin-border.css);
@import url(css/dialog_forms.css);
@import url(css/slate_fusion.css);
</style>
<!--[if IE 7]>
<style>
@import url(css/slate_ie7.css);
</style>
<![endif]-->
</head>
<body>
<div id="AppContainer">
  <div id="SplitterArea">
    <div id="Si" style="BACKGROUND-COLOR: green;">
    </div>
    <div id="SplitterArea2">
		<div id="Ma" style="BACKGROUND-COLOR: red;">
		</div>
		<div id="De" style="BACKGROUND-COLOR: blue;">
	    </div>
	</div>
  </div>
</div>
</body>
</html>
Thanks for your help!
Kevin
Paul Spencer-2 wrote:
> darn, me too ... can you send you current page (complete)
> Paul
> On 12-Dec-08, at 11:07 AM, kde wrote:
>> Thanks Paul. Now I can see the second DIV (the red one) but not the
>> third DIV
>> (the blue one).
>> I tried with several sizes but I can't make it work. The third DIV
>> is too
>> little to be visible. It seems that the second DIV use all the heigh
>> of the
>> window (it is what I see when I inspect the DOM tree of the page)
>> PS: I'm using Firefox 3
>>> Hi - you need to join the list if you want to post questions
>>> otherwise.
>>> I just copied and pasted your code into an HTML file and loaded it
>>> and
>>> I see a green rectangle covering the left half of the viewport and a
>>> red rectangle covering the top right quarter and a blue rectangle
>>> covering the bottom right.  However, this is not exactly what the
>>> code
>>> is asking for.  The problem is that the splitters manage the content
>>> areas but you are also creating Jx.Layout objects to manage the
>>> content areas, so there is a confict.
>>> Removing the extra Jx.Layout and the default options, the code should
>>> look like:
>>> var main;
>>>         top: 2
>>>         left: 2,
>>>         right: 2,
>>>         top: 2,
>>>         bottom: 2
>>>     /* SPLITTER 1 */
>>>     var splitter = new Jx.Splitter('SplitterArea', {
>>> 		containerOptions: [{width: 200}, null]
>>> 	/* SPLITTER 2 */
>>>     var splitter2 = new Jx.Splitter('SplitterArea2',{
>>>         layout:'vertical',
>>> 		containerOptions: [{height: 200}, null]
>>>     main.resize();
>>> </script>
>>> Cheers
>>> Paul
>>> On 12-Dec-08, at 6:56 AM, kde wrote:
>>>> Hi everybody,
>>>> I have a blocking problem with Jx and its Splitters.
>>>> I want the split horizontaly the page in 2 parts and split the
>>>> second parts
>>>> verticaly in 2.
>>>> But when I load this simpliest code (this html file is wel located
>>>> in a
>>>> fusion template folder with all required xml/css/images (I use a
>>>> copy of
>>>> "Slate")), I see only the "Si" DIV (the green one).
>>>> <html>
>>>> <head>
>>>> <title>Test</title>
>>>> script>
>>>> var main;
>>>> main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2,
>>>> bottom:
>>>> 0});
>>>> var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top: 2,
>>>> bottom: 2});
>>>> var si = new Jx.Layout('Si', {});
>>>> var sa2 = new Jx.Layout('SplitterArea2', {});
>>>> var ma = new Jx.Layout('Ma', {});
>>>> var de = new Jx.Layout('De', {});
>>>> /* SPLITTER 1 */
>>>>                                {splitInto:2,
>>>> /* SPLITTER 2 */
>>>>                                {splitInto:2,
>>>>                                layout:'vertical',
>>>> main.resize();
>>>> </script>
>>>> </style>
>>>> <!--[if IE 7]>
>>>> <style>
>>>> </style>
>>>> <![endif]-->
>>>> </head>
>>>> <body>
>>>>   </div>
>>>> 		</div>
>>>> 	    </div>
>>>> 	</div>
>>>> </div>
>>>> </div>
>>>> </body>
>>>> </html>
>>>> What is wrong in this code?
>>>> Thanks in advance for your suggestion
>>>> View this message in context:
>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> fusion-users mailing list
>>>> fusion-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>    Paul Spencer
>>>    Chief Technology Officer
>>>    DM Solutions Group Inc
>>>    http://research.dmsolutions.ca/
>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648372.html
>     Paul Spencer
View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648529.html
More information about the fusion-users mailing list
