[fusion-users] Nested JxSplitters which don't want to work
Paul Spencer pspencer at dmsolutions.ca
Fri Dec 12 11:36:51 EST 2008
try removing height: auto and just use {} instead
Paul
On 12-Dec-08, at 11:29 AM, kde wrote:
> Here is the current page :
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
> "http://www.w3.org/TR/html4/strict.dtd">
> <html>
> <head>
> <title>Test</title>
> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
> <script type="text/javascript" src="../../../lib/fusion.js"></script>
> <script type="text/javascript">
> var main;
> window.onload = function() {
>  main = new Jx.Layout('AppContainer', {
>         top: 2
>  var sa1 = new Jx.Layout('SplitterArea', {
>         left: 2,
>         right: 2,
>         top: 2,
>         bottom: 2
>  /* SPLITTER 1 */
>  var splitter = new Jx.Splitter('SplitterArea',
> 								 elements: [$('Si'), $('SplitterArea2')],
>                                 layout:'horizontal',
> 								 containerOptions: [{width: 200}]
>  /* SPLITTER 2 */
>  var splitter2 = new Jx.Splitter('SplitterArea2',
>                                 elements:[$('Ma'), $('De')],
>                                 layout:'vertical',
> 								 containerOptions: [{height: 200}, {height: auto}]
>  main.resize();
> </script>
> <style type="text/css">
> @import url(css/jxskin-border.css);
> @import url(css/dialog_forms.css);
> @import url(css/slate_fusion.css);
> </style>
> <!--[if IE 7]>
> <style>
> @import url(css/slate_ie7.css);
> </style>
> <![endif]-->
> </head>
> <body>
> <div id="AppContainer">
>  <div id="SplitterArea">
>    <div id="Si" style="BACKGROUND-COLOR: green;">
>    </div>
>    <div id="SplitterArea2">
> 		<div id="Ma" style="BACKGROUND-COLOR: red;">
> 		</div>
> 		<div id="De" style="BACKGROUND-COLOR: blue;">
> 	    </div>
> 	</div>
>  </div>
> </div>
> </body>
> </html>
> Thanks for your help!
> Kevin
> Paul Spencer-2 wrote:
>> darn, me too ... can you send you current page (complete)
>> Paul
>> On 12-Dec-08, at 11:07 AM, kde wrote:
>>> Thanks Paul. Now I can see the second DIV (the red one) but not the
>>> third DIV
>>> (the blue one).
>>> I tried with several sizes but I can't make it work. The third DIV
>>> is too
>>> little to be visible. It seems that the second DIV use all the heigh
>>> of the
>>> window (it is what I see when I inspect the DOM tree of the page)
>>> PS: I'm using Firefox 3
>>>> Hi - you need to join the list if you want to post questions
>>>> otherwise.
>>>> I just copied and pasted your code into an HTML file and loaded it
>>>> and
>>>> I see a green rectangle covering the left half of the viewport
>>>> and a
>>>> red rectangle covering the top right quarter and a blue rectangle
>>>> covering the bottom right.  However, this is not exactly what the
>>>> code
>>>> is asking for.  The problem is that the splitters manage the
>>>> content
>>>> areas but you are also creating Jx.Layout objects to manage the
>>>> content areas, so there is a confict.
>>>> Removing the extra Jx.Layout and the default options, the code
>>>> should
>>>> look like:
>>>> var main;
>>>>        top: 2
>>>>        left: 2,
>>>>        right: 2,
>>>>        top: 2,
>>>>        bottom: 2
>>>>    /* SPLITTER 1 */
>>>>    var splitter = new Jx.Splitter('SplitterArea', {
>>>> 		containerOptions: [{width: 200}, null]
>>>> 	/* SPLITTER 2 */
>>>>    var splitter2 = new Jx.Splitter('SplitterArea2',{
>>>>        layout:'vertical',
>>>> 		containerOptions: [{height: 200}, null]
>>>>    main.resize();
>>>> </script>
>>>> Cheers
>>>> Paul
>>>> On 12-Dec-08, at 6:56 AM, kde wrote:
>>>>> Hi everybody,
>>>>> I have a blocking problem with Jx and its Splitters.
>>>>> I want the split horizontaly the page in 2 parts and split the
>>>>> second parts
>>>>> verticaly in 2.
>>>>> But when I load this simpliest code (this html file is wel located
>>>>> in a
>>>>> fusion template folder with all required xml/css/images (I use a
>>>>> copy of
>>>>> "Slate")), I see only the "Si" DIV (the green one).
>>>>> <html>
>>>>> <head>
>>>>> <title>Test</title>
>>>>> charset=utf-8">
>>>>> script>
>>>>> var main;
>>>>> main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2,
>>>>> bottom:
>>>>> 0});
>>>>> var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top:
>>>>> 2,
>>>>> bottom: 2});
>>>>> var si = new Jx.Layout('Si', {});
>>>>> var sa2 = new Jx.Layout('SplitterArea2', {});
>>>>> var ma = new Jx.Layout('Ma', {});
>>>>> var de = new Jx.Layout('De', {});
>>>>> /* SPLITTER 1 */
>>>>>                               {splitInto:2,
>>>>> /* SPLITTER 2 */
>>>>>                               {splitInto:2,
>>>>>                               layout:'vertical',
>>>>> main.resize();
>>>>> </script>
>>>>> </style>
>>>>> <!--[if IE 7]>
>>>>> <style>
>>>>> </style>
>>>>> <![endif]-->
>>>>> </head>
>>>>> <body>
>>>>>  </div>
>>>>> 		</div>
>>>>> 	    </div>
>>>>> 	</div>
>>>>> </div>
>>>>> </div>
>>>>> </body>
>>>>> </html>
>>>>> What is wrong in this code?
>>>>> Thanks in advance for your suggestion
>>>>> View this message in context:
>>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
>>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> fusion-users mailing list
>>>>> fusion-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>>   Paul Spencer
>>>>   Chief Technology Officer
>>>>   DM Solutions Group Inc
>>>>   http://research.dmsolutions.ca/
>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648372.html
>>    Paul Spencer
> View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648529.html
    Paul Spencer
More information about the fusion-users mailing list
