[fusion-users] Nested JxSplitters which don't want to work
kde kdelcroix at celsius-tech.com
Fri Dec 12 11:45:39 EST 2008
Sorry, I forgot to remove the "height: auto" in the code I post. But I
already tried without and it doesn't work.
Paul Spencer-2 wrote:
> try removing height: auto and just use {} instead
> Paul
> On 12-Dec-08, at 11:29 AM, kde wrote:
>> Here is the current page :
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
>> "http://www.w3.org/TR/html4/strict.dtd">
>> <html>
>> <head>
>> <title>Test</title>
>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>> <script type="text/javascript" src="../../../lib/fusion.js"></script>
>> <script type="text/javascript">
>> var main;
>> window.onload = function() {
>>  main = new Jx.Layout('AppContainer', {
>>         top: 2
>>  var sa1 = new Jx.Layout('SplitterArea', {
>>         left: 2,
>>         right: 2,
>>         top: 2,
>>         bottom: 2
>>  /* SPLITTER 1 */
>>  var splitter = new Jx.Splitter('SplitterArea',
>> 								 elements: [$('Si'), $('SplitterArea2')],
>>                                 layout:'horizontal',
>> 								 containerOptions: [{width: 200}]
>>  /* SPLITTER 2 */
>>  var splitter2 = new Jx.Splitter('SplitterArea2',
>>                                 elements:[$('Ma'), $('De')],
>>                                 layout:'vertical',
>> 								 containerOptions: [{height: 200}, {height: auto}]
>>  main.resize();
>> </script>
>> <style type="text/css">
>> @import url(css/jxskin-border.css);
>> @import url(css/dialog_forms.css);
>> @import url(css/slate_fusion.css);
>> </style>
>> <!--[if IE 7]>
>> <style>
>> @import url(css/slate_ie7.css);
>> </style>
>> <![endif]-->
>> </head>
>> <body>
>> <div id="AppContainer">
>>  <div id="SplitterArea">
>>    <div id="Si" style="BACKGROUND-COLOR: green;">
>>    </div>
>>    <div id="SplitterArea2">
>> 		<div id="Ma" style="BACKGROUND-COLOR: red;">
>> 		</div>
>> 		<div id="De" style="BACKGROUND-COLOR: blue;">
>> 	    </div>
>> 	</div>
>>  </div>
>> </div>
>> </body>
>> </html>
>> Thanks for your help!
>> Kevin
>>> darn, me too ... can you send you current page (complete)
>>> Paul
>>> On 12-Dec-08, at 11:07 AM, kde wrote:
>>>> Thanks Paul. Now I can see the second DIV (the red one) but not the
>>>> third DIV
>>>> (the blue one).
>>>> I tried with several sizes but I can't make it work. The third DIV
>>>> is too
>>>> little to be visible. It seems that the second DIV use all the heigh
>>>> of the
>>>> window (it is what I see when I inspect the DOM tree of the page)
>>>> PS: I'm using Firefox 3
>>>>> Hi - you need to join the list if you want to post questions
>>>>> otherwise.
>>>>> I just copied and pasted your code into an HTML file and loaded it
>>>>> and
>>>>> I see a green rectangle covering the left half of the viewport
>>>>> and a
>>>>> red rectangle covering the top right quarter and a blue rectangle
>>>>> covering the bottom right.  However, this is not exactly what the
>>>>> code
>>>>> is asking for.  The problem is that the splitters manage the
>>>>> content
>>>>> areas but you are also creating Jx.Layout objects to manage the
>>>>> content areas, so there is a confict.
>>>>> Removing the extra Jx.Layout and the default options, the code
>>>>> should
>>>>> look like:
>>>>> var main;
>>>>>        top: 2
>>>>>        left: 2,
>>>>>        right: 2,
>>>>>        top: 2,
>>>>>        bottom: 2
>>>>>    /* SPLITTER 1 */
>>>>>    var splitter = new Jx.Splitter('SplitterArea', {
>>>>> 		containerOptions: [{width: 200}, null]
>>>>> 	/* SPLITTER 2 */
>>>>>    var splitter2 = new Jx.Splitter('SplitterArea2',{
>>>>>        layout:'vertical',
>>>>> 		containerOptions: [{height: 200}, null]
>>>>>    main.resize();
>>>>> </script>
>>>>> Cheers
>>>>> Paul
>>>>> On 12-Dec-08, at 6:56 AM, kde wrote:
>>>>>> Hi everybody,
>>>>>> I have a blocking problem with Jx and its Splitters.
>>>>>> I want the split horizontaly the page in 2 parts and split the
>>>>>> second parts
>>>>>> verticaly in 2.
>>>>>> But when I load this simpliest code (this html file is wel located
>>>>>> in a
>>>>>> fusion template folder with all required xml/css/images (I use a
>>>>>> copy of
>>>>>> "Slate")), I see only the "Si" DIV (the green one).
>>>>>> <html>
>>>>>> <head>
>>>>>> <title>Test</title>
>>>>>> charset=utf-8">
>>>>>> script>
>>>>>> var main;
>>>>>> main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2,
>>>>>> bottom:
>>>>>> 0});
>>>>>> var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top:
>>>>>> 2,
>>>>>> bottom: 2});
>>>>>> var si = new Jx.Layout('Si', {});
>>>>>> var sa2 = new Jx.Layout('SplitterArea2', {});
>>>>>> var ma = new Jx.Layout('Ma', {});
>>>>>> var de = new Jx.Layout('De', {});
>>>>>> /* SPLITTER 1 */
>>>>>>                               {splitInto:2,
>>>>>> /* SPLITTER 2 */
>>>>>>                               {splitInto:2,
>>>>>>                               layout:'vertical',
>>>>>> main.resize();
>>>>>> </script>
>>>>>> </style>
>>>>>> <!--[if IE 7]>
>>>>>> <style>
>>>>>> </style>
>>>>>> <![endif]-->
>>>>>> </head>
>>>>>> <body>
>>>>>>  </div>
>>>>>> 		</div>
>>>>>> 	    </div>
>>>>>> 	</div>
>>>>>> </div>
>>>>>> </div>
>>>>>> </body>
>>>>>> </html>
>>>>>> What is wrong in this code?
>>>>>> Thanks in advance for your suggestion
>>>>>> View this message in context:
>>>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
>>>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>>>> _______________________________________________
>>>>>> fusion-users mailing list
>>>>>> fusion-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>>>   Paul Spencer
>>>>>   Chief Technology Officer
>>>>>   DM Solutions Group Inc
>>>>>   http://research.dmsolutions.ca/
>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648372.html
>>>    Paul Spencer
>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648529.html
>     Paul Spencer
View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648589.html
More information about the fusion-users mailing list
