[fusion-users] Nested JxSplitters which don't want to work
Paul Spencer
pspencer at dmsolutions.ca
Fri Dec 12 11:51:06 EST 2008
I'm not sure what else ... using your exact HTML below (less the
height: auto) works for me
Actually, there is one difference ... the css files aren't loading for
me because the html page is in a different place (I adjusted the path
to fusion.js appropriately). Try removing the style blocks and see
what happens.
Cheers
Paul
On 12-Dec-08, at 11:45 AM, kde wrote:
> Sorry, I forgot to remove the "height: auto" in the code I post. But I
> already tried without and it doesn't work.
> Paul Spencer-2 wrote:
>> try removing height: auto and just use {} instead
>> Paul
>> On 12-Dec-08, at 11:29 AM, kde wrote:
>>> Here is the current page :
>>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
>>> "http://www.w3.org/TR/html4/strict.dtd">
>>> <html>
>>> <head>
>>> <title>Test</title>
>>> <meta http-equiv="Content-type" content="text/html; charset=utf-8">
>>> <script type="text/javascript" src="../../../lib/fusion.js"></
>>> script>
>>> <script type="text/javascript">
>>> var main;
>>> window.onload = function() {
>>> main = new Jx.Layout('AppContainer', {
>>> top: 2
>>> var sa1 = new Jx.Layout('SplitterArea', {
>>> left: 2,
>>> right: 2,
>>> top: 2,
>>> bottom: 2
>>> /* SPLITTER 1 */
>>> var splitter = new Jx.Splitter('SplitterArea',
>>> elements: [$('Si'), $('SplitterArea2')],
>>> layout:'horizontal',
>>> containerOptions: [{width: 200}]
>>> /* SPLITTER 2 */
>>> var splitter2 = new Jx.Splitter('SplitterArea2',
>>> elements:[$('Ma'), $('De')],
>>> layout:'vertical',
>>> containerOptions: [{height: 200}, {height: auto}]
>>> main.resize();
>>> </script>
>>> <style type="text/css">
>>> @import url(css/jxskin-border.css);
>>> @import url(css/dialog_forms.css);
>>> @import url(css/slate_fusion.css);
>>> </style>
>>> <!--[if IE 7]>
>>> <style>
>>> @import url(css/slate_ie7.css);
>>> </style>
>>> <![endif]-->
>>> </head>
>>> <body>
>>> <div id="AppContainer">
>>> <div id="SplitterArea">
>>> <div id="Si" style="BACKGROUND-COLOR: green;">
>>> </div>
>>> <div id="SplitterArea2">
>>> <div id="Ma" style="BACKGROUND-COLOR: red;">
>>> </div>
>>> <div id="De" style="BACKGROUND-COLOR: blue;">
>>> </div>
>>> </div>
>>> </div>
>>> </div>
>>> </body>
>>> </html>
>>> Thanks for your help!
>>> Kevin
>>>> darn, me too ... can you send you current page (complete)
>>>> Paul
>>>> On 12-Dec-08, at 11:07 AM, kde wrote:
>>>>> Thanks Paul. Now I can see the second DIV (the red one) but not
>>>>> the
>>>>> third DIV
>>>>> (the blue one).
>>>>> I tried with several sizes but I can't make it work. The third DIV
>>>>> is too
>>>>> little to be visible. It seems that the second DIV use all the
>>>>> heigh
>>>>> of the
>>>>> window (it is what I see when I inspect the DOM tree of the page)
>>>>> PS: I'm using Firefox 3
>>>>>> Hi - you need to join the list if you want to post questions
>>>>>> otherwise.
>>>>>> I just copied and pasted your code into an HTML file and loaded
>>>>>> it
>>>>>> and
>>>>>> I see a green rectangle covering the left half of the viewport
>>>>>> and a
>>>>>> red rectangle covering the top right quarter and a blue rectangle
>>>>>> covering the bottom right. However, this is not exactly what the
>>>>>> code
>>>>>> is asking for. The problem is that the splitters manage the
>>>>>> content
>>>>>> areas but you are also creating Jx.Layout objects to manage the
>>>>>> content areas, so there is a confict.
>>>>>> Removing the extra Jx.Layout and the default options, the code
>>>>>> should
>>>>>> look like:
>>>>>> var main;
>>>>>> top: 2
>>>>>> left: 2,
>>>>>> right: 2,
>>>>>> top: 2,
>>>>>> bottom: 2
>>>>>> /* SPLITTER 1 */
>>>>>> var splitter = new Jx.Splitter('SplitterArea', {
>>>>>> containerOptions: [{width: 200}, null]
>>>>>> /* SPLITTER 2 */
>>>>>> var splitter2 = new Jx.Splitter('SplitterArea2',{
>>>>>> layout:'vertical',
>>>>>> containerOptions: [{height: 200}, null]
>>>>>> main.resize();
>>>>>> </script>
>>>>>> Cheers
>>>>>> Paul
>>>>>> On 12-Dec-08, at 6:56 AM, kde wrote:
>>>>>>> Hi everybody,
>>>>>>> I have a blocking problem with Jx and its Splitters.
>>>>>>> I want the split horizontaly the page in 2 parts and split the
>>>>>>> second parts
>>>>>>> verticaly in 2.
>>>>>>> But when I load this simpliest code (this html file is wel
>>>>>>> located
>>>>>>> in a
>>>>>>> fusion template folder with all required xml/css/images (I use a
>>>>>>> copy of
>>>>>>> "Slate")), I see only the "Si" DIV (the green one).
>>>>>>> <html>
>>>>>>> <head>
>>>>>>> <title>Test</title>
>>>>>>> charset=utf-8">
>>>>>>> script>
>>>>>>> var main;
>>>>>>> main = new Jx.Layout('AppContainer', {left: 0, right: 0, top: 2,
>>>>>>> bottom:
>>>>>>> 0});
>>>>>>> var sa1 = new Jx.Layout('SplitterArea', {left: 2, right: 2, top:
>>>>>>> 2,
>>>>>>> bottom: 2});
>>>>>>> var si = new Jx.Layout('Si', {});
>>>>>>> var sa2 = new Jx.Layout('SplitterArea2', {});
>>>>>>> var ma = new Jx.Layout('Ma', {});
>>>>>>> var de = new Jx.Layout('De', {});
>>>>>>> /* SPLITTER 1 */
>>>>>>> {splitInto:2,
>>>>>>> /* SPLITTER 2 */
>>>>>>> {splitInto:2,
>>>>>>> layout:'vertical',
>>>>>>> main.resize();
>>>>>>> </script>
>>>>>>> </style>
>>>>>>> <!--[if IE 7]>
>>>>>>> <style>
>>>>>>> </style>
>>>>>>> <![endif]-->
>>>>>>> </head>
>>>>>>> <body>
>>>>>>> </div>
>>>>>>> </div>
>>>>>>> </div>
>>>>>>> </div>
>>>>>>> </div>
>>>>>>> </div>
>>>>>>> </body>
>>>>>>> </html>
>>>>>>> What is wrong in this code?
>>>>>>> Thanks in advance for your suggestion
>>>>>>> View this message in context:
>>>>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1647461.html
>>>>>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>>>>>> _______________________________________________
>>>>>>> fusion-users mailing list
>>>>>>> fusion-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>>>> Paul Spencer
>>>>>> Chief Technology Officer
>>>>>> DM Solutions Group Inc
>>>>>> http://research.dmsolutions.ca/
>>>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648372.html
>>>> Paul Spencer
>>> http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648529.html
>> Paul Spencer
> View this message in context: http://n2.nabble.com/Nested-JxSplitters-which-don%27t-want-to-work-tp1647461p1648589.html
Paul Spencer
More information about the fusion-users
