[fusion-users] Fusion release 1.0.5
Zac Spitzer zac.spitzer at gmail.com
Sat May 10 00:13:22 EDT 2008
Mike,
For Issue #2. I just sent you the details for my server via email. The
scale was being reported with decimal places, I was lazy, sorry for an
confusion there.
None of the fusion maps in the Sheboygan Sample are tiled which I
think should be addressed as this is everyone's default test set. I
will file a ticket on under the mapguide trac for this ( the server is
down at the moment )
What everyone's opinion of encouraging users to install from
subversion? (via tags etc)
I created a ticket for the report server connection error
http://trac.osgeo.org/fusion/ticket/61
z
On Sat, May 10, 2008 at 1:03 AM, Mike Adair <madair at dmsolutions.ca> wrote:
> Zac,
> Thanks for testing.  Perhaps we should put in place some sort of RC process
> to shake out bugs like this.
> I've got a fix for the StatusBar problem in Fusion, but getting that out
> there would require another release.  I'm not sure why that doesn't occur
> with the standard template, but the solution is to force a resize on
> Container elements once they get created.
> For issue #2, with the slate template I'm seeing 87.7045, 43.7656 at the
> intersection of Park Ave and N 3rd St. which I think is the correct
> coordinates.  Are you only getting 2 digits of precision?  Make sure that
> the CursorPosition widget has     <Precision>4</Precision> in it's
> <Extension> element.  If that's not the case can you point me to a URL that
> shows the incorrect locations?
> For the MgServer crashing issue, that wasn't addressed in the release, but
> it would be good to do something about that in a future release.  Can you
> enter a trac ticket for it please?
> Thanks again for the reports.
> Mike
> Zac Spitzer wrote:
>> ok, i did that. I renamed the folder, installed 1.0.5  and then copied
>> across the mg templates
>> from the old fusion/templates/mapguide directory
>> It works ok, but the status bar elements are all on top of each other
>> also, my mgserver had crashed (again) and fusion just sits there doing
>> nothing without any
>> feedback that there was no response from mapguide
>> http://trac.osgeo.org/fusion/ticket/2 is still not working, i getting
>> 88 44 instead of 87 43
>> z
>> On Fri, May 9, 2008 at 11:43 AM, Jason Birch <Jason.Birch at nanaimo.ca>
>> wrote:
>>> Rename it / back it up.
>>>  You'll need to copy the MapGuide templates from the distributed fusion
>>> folder into the new fusion folder after installing.  I haven't had a chance
>>> to test this release yet :(
>>>  Jason
>>>  ________________________________
>>>  From: Zac Spitzer
>>>  Subject: Re: [fusion-users] Fusion release 1.0.5
>>>  To install on an existing mapgudie instance, do we overwrite the
>>>  fusion folder or should i delete it first?
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
More information about the fusion-users mailing list
