[fusion-users] Multiple Maps and OverviewMap.
Mike Adair madair at dmsolutions.ca
Fri May 16 09:21:25 EDT 2008
Tomas,
I've never tried putting 2 MapWidgets in one template before so there
will likely be some issues around that, but Fusion is currently set up
to have 1 MapWidget per WidgetSet.  So if you still want to try this,
put the second MapWidget inside a second WidgetSet element in AppDef.
Putting more than one MapGroup element inside the MapSet has been tested
and should work OK.  The Map to be shown by a MapWidget is selected by
the ID attribute.
Putting more than one Map inside a MapGroup isn't supported yet, but it
is being worked on and planned for the 1.1 release.
As for your OverviewMap questions, the MinRatio and MaxRatio options
should be getting passed in to the control correctly (please file a
ticket if they are not) but to be honest, I have a hard time figuring
out how the OpenLayers control behaves too.  It may help to define a
separate MapGroup for the overview (provide a <MapId> in it's extension)
so that you can specify different minScale and maxScale values that are
more appropriate for an overview map, rather than using a copy of the
main map layer.
Hope that helps,
Mike
Tómas Guðmundsson wrote:
> Hi all.
> Happy Friday. Hope you have a wonderful weekend everyone. I have a couple questions for you all.
> First of regarding the maps. I thought originally that it would be enough to add these two things to the ApplicationDefinition.xml and life would be beautiful but I guess I'm not that lucky.
> 1.
> <MapWidget xsi:type="WidgetType">
> <Name>Map</Name>
> <Type>Map</Type>
> <StatusText>The map.</StatusText>
> <MapId>sheboygan</MapId>
> <Extension xsi:type="CustomContentType">
> <MenuContainer>ContextMenu</MenuContainer>
> </Extension>
> </MapWidget>
> 2.
> <MapGroup id="sheboygan" xsi:type="MapType">
> <Map xsi:type="MapGuideLayerType">
> <Type>MapGuide</Type>
> <SingleTile>true</SingleTile>
> <Extension>
> <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</ResourceId>
> </Extension>
> </Map>
> </MapGroup>
> And with those two added to my AppDef I was hoping to have my main map and then the sample map as well so I could chose between in the <Widget>MapMenu</Widget> but nothing happens. I also get some errors that I think that are encountered with reading between the maps. Just to clear things, I added the MapGroup within the MapSet in the AppDef so I would have two MapGroups and two MapWidgets but I also tried to have two Maps within one MapGroup. Nothing worked.
> My second question is regarding the OverviewMap. I played a little with the OverviewMap.js and the OverviewMap.xml to see if it would make any changes and nothing happen. Essentially I tried to change some variables like the min and max ratio, oLayerOL.ratio and numZoomLevels but what I'm trying to change in my overviewmap is when you zoom in, in the big map that the overview map doesn't change as well. So after I zoom in 3 times, the overview map starts to zoom in as well and at that time the red binding box in the overview map is so big that it's not feasible to pan around in the overview map. So how can I change the overview map so it that the overview map would never, or after 10 times zoom in. Note: Changing these lines (the value assigned) did not help.
>         if (this.mapObject.oLayerOL.singleTile) {
>           this.oMapOptions.numZoomLevels = 3;  //TODO: make this configurable?
> Also everyone. Have a great weekend. You know it's going to be fun!
> Regards,
> Tómas.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
More information about the fusion-users mailing list
