[fusion-users] Panels and instantiations.
Tómas Guðmundsson tomas at snertill.is
Fri May 30 09:14:34 EDT 2008
Hi Jason.
Yes this was what I was looking for. Just got back from lunch so I'll look into it.  It looks to me like that is how you get a new Widget *in* to a panel like Paul talked about. I have currently mastered the Jx.Panels and done something cool with them. I thought of an idea that might be bad it might be good, don't know 100% how this was designed. But if some widget's like the Legend would Inherit or extend a Jx.Panel so functionality of a panel might be configurable / controllable by the widget itself. For instance, when a panel is maximized (which I think is no way for the widget Legend to find out) it might call for a selection in the map and do something with that. Just wandering right now, there might be some hidden functionality in there.
Regards,
Tómas.
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Jason Fournier
Sent: 30. maí 2008 11:44
To: fusion-users at lists.osgeo.org
Subject: RE: [fusion-users] Panels and instantiations.
Hi Tomas,
If I follow you correctly I seem to recall Panels getting created in Jx and then applying a content.id to attach to a widget in the AppDef:
    var p1 = new Jx.Panel({label: 'Legend'});
    p1.content.id = 'Legend';
in your AppDef you'd have a widget with Name Legend.
This was a while ago so things might have changed since.
Best regards,
Jason
From: fusion-users-bounces at lists.osgeo.org [mailto:fusion-users-bounces at lists.osgeo.org] On Behalf Of Tómas Guðmundsson
Sent: Friday, May 30, 2008 7:24 AM
Subject: [fusion-users] Panels and instantiations.
Hi all.
I am trying to figure out how and where widget's like TaskPane and Legend.js get instantiated ? Is it onely from ApplicationDefinition.xml  or is it somewhere called in fusion.js or fusion.combined.js ? Any help to how to construct a Panel Widget would be very helpful.
Regards
Tómas from the very recently earthquake shooken Iceland.
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080530/101d6dfd/attachment.html
More information about the fusion-users mailing list
