[fusion-users] Unmanaged datasource/FeatureSource
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Nov 27 15:21:49 EST 2008
There is no difference in managed versus unmanaged for the functionality
side of things, performance should be the same as well.
If you have used Studio to load the SHP files, it might do something to
the data, eg. convert it to SDF, build bounds, set coordsys etc.
I suspect that the FeatureSource is missing some coordinate system
information.
You may get better answers on the mapguide-users list.
Regards, Kenneth Skovhede, GEOGRAF A/S
Suhaimi AK skrev:
> Ok, this is my another question.
> I have created ne datasource/FeatureSource of unmanaged shp file as follows:
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>   <Provider>OSGeo.SHP</Provider>
>   <Parameter>
>     <Name>DefaultFileLocation</Name>
>     <Value>C:\Map\road.shp</Value>
>   </Parameter>
>   <Parameter>
>     <Name>TemporaryFileLocation</Name>
>     <Value />
>   </Parameter>
> </FeatureSource>
> When preview the item, the road map displayed as expected.
> Unfortunately, when i view through map, it did not displayed. Is there a
> different using Internal file (Managed) and File on server (Unmanaged). This
> is my first time using unmanaged featuresourse because file.dbf is too
> large, and i cannot upload it using managed featuresource.
> Anybody can help me?
> Thank you in advance.
> Regards,
> Suhaimi AK
More information about the fusion-users mailing list
