[fusion-users] Error selecting features on a layer using SHP with join
Rodolfo Moreno rmoreno at voxiva.com
Thu Nov 27 23:55:51 EST 2008
Hi developers, I have posted this subject but without any answer.
I don't know exactly whether or not it's an issue, but I guess that it's
important to evaluate this problem due to layer with join is a common use in
many fusion applications.
Cheers,
Rodolfo Moreno wrote:
> A layer using SHP WITH JOIN is displayed correctly and I can select almost
> all its features except the feature that has as featId=1 (I have tested in
> IE7 and FF2 obtain the same result).
> SHP WITH JOIN: It's a shp(data source) which has a join to a database in
> order to add properties from the database.
> I have created a ticket for MGOS project for an error related "Error
> theming layer using data source with joins"
> (http://trac.osgeo.org/mapguide/ticket/745)
> In this ticket there are two files (database access and mgp file for MGOS)
> that allow replicate this error.
> I have tested for manage and unmanage data source, just as SHP, SDF, and
> SQL2008 providers as well.
> plataform: w2003 sp2, IIS 6, MGOS 2.0.1, FUSION 1.0.6 and .NET enviroment
> Is it issue known?
> Cheers,
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Error-selecting-features-on-a-layer-using-SHP-with-join-tp1400932p1587892.html
Sent from the Fusion Users mailing list archive at Nabble.com.
More information about the fusion-users mailing list
