[fusion-users] Demo works in HostLinux but not Ubuntu 8.04 Server
Mike Adair madair at dmsolutions.ca
Tue Oct 28 13:34:12 EDT 2008
Not sure if this is an issue on Ubuntu, but on my Windows machine,
MapServer doesn't let you use localhost as the domain name (check the
error coming back from the image request in Firebug by opening that URL
in a new tab - i get an 'invalid mode' error).  I get around this by
setting the MapServer cgi parameter to something like:
       "cgi": "http://127.0.0.1/cgi-bin/mapserv",
Mike
Andrew Parker wrote:
> Ok, I must be missing the obvious as I still cannot see the demo.  I
> made the changes per Paul D's suggestions (see below).
> This is what I did:
> 1. verified that the ServerRoot is "/etc/apache2"
> 2. verified that the DocumentRoot is set to "/var/www"
> 3. verified that "/etc/ apache2/tmp" exists and permissions set to 777
> 4. verfied that "/var/www/tmp/ms_tmp" exists and permissions set to 777
> 5. Modified Fusions' config.json as shown below
> 5. Restarted apache2
> current configuration of config.json:
> /* This is the fusion configuration file.  Adjust as necessary. */
>    /* The general section contains settings that are general to
>       fusion as a whole. */
>    "general": {
>        /* PHP is the default and only script language supported.
>           Don"t change this. */
>        "scriptLanguage": "php",
>        /* A directory on this system that fusion can use for
>           temporary files. */
>        "temporaryDirectory": "/etc/apache2/tmp"
>    /* The MapGuide section is required if you are installing
>       fusion for MapGuide. */
>    "mapguide": {
>        /* The WebTierURL is the url to mapguide, it should start
>           with http and end with /mapguide.  If you have installed
>           fusion inside the www directory of MapGuide, then you can
>           leave this empty as it will be automatically calculated. */
>           "webTierUrl": ""
>    /* The MapServer section is required if you are installing fusion
>       for MapServer. */
>   "mapserver": {
>        /* The URL of the mapserver CGI that you want to use.  */
>        "cgi": "/cgi-bin/mapserv",
>        /* The file system path to where mapserver should put
>            web-accessible temporary images. */
>        "imagePath": "/var/www/tmp/ms_tmp",
>        /* The URL to the image path configured above. */
>        "imageUrl": "http://localhost/tmp/ms_tmp",
>            web-accessible temporary legend images. */
>        "legendIconCacheDir":"/var/www/tmp/ms_tmp"
> Any other setting/configurations I should check?
> In a twisted sort of way, I love this debugging stuff!
> ~andrew
> Paul Deschamps wrote:
>> Your problem is right there in your config.
>>          temporary files. */
>>       "temporaryDirectory": "/tmp"
>> should be:
>> also look at the image path and imageURL values.
>>       "imagePath": "/tmp/ms_tmp",
>>       "legendIconCacheDir":"/tmp/ms_
>>     tmp"
>> Cheers
>> Paul D
>> On Tue, Oct 28, 2008 at 9:51 AM, Andrew Parker <andrew at source3.com
>> <mailto:andrew at source3.com>> wrote:
>>     I got the Fusion Demo working as discussed in
>> http://n2.nabble.com/Mapfile-not-displaying-in-Fusion-for-MapServer-td1379147.html.
>>      The working Demo uses HostLinux offered by HostGIS.
>>     When I try to view the Demo using Ubuntu 8.04 server (and Ubuntu
>>     7.10) I can only see the html layout, no layer tree or toolbars.
>>      However, I can see the mapfile using
>> http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map
>> <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>.
>>     I think the problem is where Fusion and MapServer is storing the
>>     temporary files.  So I started playing around with the paths.  The
>>     config.json file is as follows:
>>       "general": {
>>              temporary files. */
>>       "mapguide": {
>>              "webTierUrl": ""
>>          for MapServer. */
>>      "mapserver": {
>>           "legendIconCacheDir":"/tmp/ms_tmp"
>>     The ServerRoot in apache2 is /etc/apache2.  The apache2
>>     DocumentRoot is /var/www.
>>     Therefore, I created the directory tmp (/etc/apache2/tmp) and set
>>     permission to 777.  Restarted apache2 and tested the demo.  Same
>>     results.  Looked in /etc/apache2/tmp and did not see any Fusion
>>     session files.  I also create the /tmp/ms_tmp directories in
>>     /var/www and /var.  No temp files were saved in these directories.
>>     Then I decided to change the SeverRoot to /var and /var/www to see
>>     what happens.  Restarted apache2 and same results, only the html
>>     layout.
>>     Know I am out of ideas.  Does anyone have an idea how to fix this.
>>      I really want to include how to get Fusion working in Ubuntu in
>>     my HowTo I am writing for grad school.
>>     Thank you very much.
>>     --     Andrew
>>     _______________________________________________
>>     fusion-users mailing list
>>     fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/fusion-users
>>    Paul Deschamps
>>    Applications Specialist
>>    DM Solutions Group Inc.
>>    Office: (613) 565-5056 x28
>>    pdeschamps at dmsolutions.ca <mailto:pdeschamps at dmsolutions.ca>
>>    http://www.dmsolutions.ca
>>    http://research.dmsolutions.ca
More information about the fusion-users mailing list
