[fusion-users] Demo works in HostLinux but not Ubuntu 8.04 Server
Andrew Parker andrew at source3.com
Tue Oct 28 15:00:24 EDT 2008
Thanks Mike for the suggestion.  I tried using 127.0.0.1.  Same issue.
In addition, I do not think that MapServer is blocking the localhost
since I can see the mapfile when I enter
http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map.
Furthermore, Firebug is not showing any errors; or at least I do not see
any.
~ andrew
Mike Adair wrote:
> Not sure if this is an issue on Ubuntu, but on my Windows machine,
> MapServer doesn't let you use localhost as the domain name (check the
> error coming back from the image request in Firebug by opening that
> URL in a new tab - i get an 'invalid mode' error).  I get around this
> by setting the MapServer cgi parameter to something like:
>       "cgi": "http://127.0.0.1/cgi-bin/mapserv",
> Mike
> Andrew Parker wrote:
>> Ok, I must be missing the obvious as I still cannot see the demo.  I
>> made the changes per Paul D's suggestions (see below).
>> This is what I did:
>> 1. verified that the ServerRoot is "/etc/apache2"
>> 2. verified that the DocumentRoot is set to "/var/www"
>> 3. verified that "/etc/ apache2/tmp" exists and permissions set to 777
>> 4. verfied that "/var/www/tmp/ms_tmp" exists and permissions set to 777
>> 5. Modified Fusions' config.json as shown below
>> 5. Restarted apache2
>> current configuration of config.json:
>> /* This is the fusion configuration file.  Adjust as necessary. */
>>    /* The general section contains settings that are general to
>>       fusion as a whole. */
>>    "general": {
>>        /* PHP is the default and only script language supported.
>>           Don"t change this. */
>>        "scriptLanguage": "php",
>>        /* A directory on this system that fusion can use for
>>           temporary files. */
>>        "temporaryDirectory": "/etc/apache2/tmp"
>>    /* The MapGuide section is required if you are installing
>>       fusion for MapGuide. */
>>    "mapguide": {
>>        /* The WebTierURL is the url to mapguide, it should start
>>           with http and end with /mapguide.  If you have installed
>>           fusion inside the www directory of MapGuide, then you can
>>           leave this empty as it will be automatically calculated. */
>>           "webTierUrl": ""
>>    /* The MapServer section is required if you are installing fusion
>>       for MapServer. */
>>   "mapserver": {
>>        /* The URL of the mapserver CGI that you want to use.  */
>>        "cgi": "/cgi-bin/mapserv",
>>        /* The file system path to where mapserver should put
>>            web-accessible temporary images. */
>>        "imagePath": "/var/www/tmp/ms_tmp",
>>        /* The URL to the image path configured above. */
>>        "imageUrl": "http://localhost/tmp/ms_tmp",
>>            web-accessible temporary legend images. */
>>        "legendIconCacheDir":"/var/www/tmp/ms_tmp"
>> Any other setting/configurations I should check?
>> In a twisted sort of way, I love this debugging stuff!
>> ~andrew
>> Paul Deschamps wrote:
>>> Your problem is right there in your config.
>>>          temporary files. */
>>>       "temporaryDirectory": "/tmp"
>>> should be:
>>> also look at the image path and imageURL values.
>>>       "imagePath": "/tmp/ms_tmp",
>>>       "legendIconCacheDir":"/tmp/ms_
>>>     tmp"
>>> Cheers
>>> Paul D
>>> On Tue, Oct 28, 2008 at 9:51 AM, Andrew Parker <andrew at source3.com
>>> <mailto:andrew at source3.com>> wrote:
>>>     I got the Fusion Demo working as discussed in
>>> http://n2.nabble.com/Mapfile-not-displaying-in-Fusion-for-MapServer-td1379147.html.
>>>      The working Demo uses HostLinux offered by HostGIS.
>>>     When I try to view the Demo using Ubuntu 8.04 server (and Ubuntu
>>>     7.10) I can only see the html layout, no layer tree or toolbars.
>>>      However, I can see the mapfile using
>>> <http://localhost/cgi-bin/mapserv?mode=map&map=/var/www/chp2/hello.map>.
>>>     I think the problem is where Fusion and MapServer is storing the
>>>     temporary files.  So I started playing around with the paths.  The
>>>     config.json file is as follows:
>>>       "general": {
>>>              temporary files. */
>>>       "mapguide": {
>>> calculated. */
>>>              "webTierUrl": ""
>>>          for MapServer. */
>>>      "mapserver": {
>>>           "legendIconCacheDir":"/tmp/ms_tmp"
>>>     The ServerRoot in apache2 is /etc/apache2.  The apache2
>>>     DocumentRoot is /var/www.
>>>     Therefore, I created the directory tmp (/etc/apache2/tmp) and set
>>>     permission to 777.  Restarted apache2 and tested the demo.  Same
>>>     results.  Looked in /etc/apache2/tmp and did not see any Fusion
>>>     session files.  I also create the /tmp/ms_tmp directories in
>>>     /var/www and /var.  No temp files were saved in these directories.
>>>     Then I decided to change the SeverRoot to /var and /var/www to see
>>>     what happens.  Restarted apache2 and same results, only the html
>>>     layout.
>>>     Know I am out of ideas.  Does anyone have an idea how to fix this.
>>>      I really want to include how to get Fusion working in Ubuntu in
>>>     my HowTo I am writing for grad school.
>>>     Thank you very much.
>>>     --     Andrew
>>>     _______________________________________________
>>>     fusion-users mailing list
>>>     fusion-users at lists.osgeo.org <mailto:fusion-users at lists.osgeo.org>
>>>     http://lists.osgeo.org/mailman/listinfo/fusion-users
>>>    Paul Deschamps
>>>    Applications Specialist
>>>    DM Solutions Group Inc.
>>>    Office: (613) 565-5056 x28
>>>    pdeschamps at dmsolutions.ca <mailto:pdeschamps at dmsolutions.ca>
>>>    http://www.dmsolutions.ca
>>>    http://research.dmsolutions.ca
More information about the fusion-users mailing list
