[fusion-users] Add HTML table inside the Jx.TreeFolder object
Rodolfo Moreno rmoreno at voxiva.com
Mon Sep 1 00:08:14 EDT 2008
Thanks Paul for your quick answer.
my use case:
a widget that shows the selected layers in JxFolders (similiar a
selectionpanel)
and if the user wants to see the selected features for some layer should
expand the folder.
The selected features should be showed in a table.
I think that is kind of widget is useful when the map has many layers and
many features displayed at the same time.
I hope that it has clarified my idea
Best regards
Paul Spencer-2 wrote:
> Hi Rodolfo,
> unfortunately the Jx.Tree code is not designed to support content that
> is not a Jx.TreeFolder or Jx.TreeItem.  This is an interesting idea,
> however.  Can you explain your use case?  I'm not promising that Jx
> will be able to do it, but I would like to know why you want to do it :)
> Cheers
> Paul
> On 29-Aug-08, at 5:15 PM, Rodolfo Moreno wrote:
>> Hi Paul,
>> excuse my rudeness for writing to you straight, but I know you are a
>> seasoned developer in Jx.
>> I want to show a HTML table after doing click to a Jx.TreeFolder
>> /* add a folder to the tree */
>>    var folder = new Jx.TreeFolder({label: 'My Folder'});
>>    tree.append(folder);
>> /* put an item into the folder */
>> var item = new Jx.TreeItem({label: 'item ' + i});
>> folder.append(item);
>> This is a sample that I found in zip file of fusion. It shows how
>> put an
>> item as a text into folder,
>> but I would like to append a HTML table into folder, is it possible?
>> Thanks in advance
>> Rodolfo Moreno
>> CivilEng
>> View this message in context:
>> http://n2.nabble.com/Add-HTML-table-inside-the-Jx.TreeFolder-object-tp793112p793112.html
>> Sent from the Fusion Users mailing list archive at Nabble.com.
>> fusion-users mailing list
>> fusion-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>     Paul Spencer
>     Chief Technology Officer
>     DM Solutions Group Inc
>     http://www.dmsolutions.ca/
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Add-HTML-table-inside-the-Jx.TreeFolder-object-tp793112p796479.html
More information about the fusion-users mailing list
