[fusion-users] Add HTML table inside the Jx.TreeFolder object
Paul Spencer pspencer at dmsolutions.ca
Tue Sep 2 07:26:55 EDT 2008
An achievable option would be to create a tree of the layers that have
selection results and have the actual results next to them:
+- My Map             +-------------------+
+-+- My Group     +-> | Selection Details |
   |-+- My Layer   |   +---------+---------+
     |-- Result 1  |   | Field 1 | Value 1 |
     |-- Result 2  |   +---------+---------+
     |-- Result 3 -+   | Field 2 | Value 2 |
     +-- Result 4      +---------+---------+
(Sorry for the horrible ascii art)
Cheers
Paul
On 1-Sep-08, at 12:08 AM, Rodolfo Moreno wrote:
> Thanks Paul for your quick answer.
> my use case:
> a widget that shows the selected layers in JxFolders (similiar a
> selectionpanel)
> and if the user wants to see the selected features for some layer
> should
> expand the folder.
> The selected features should be showed in a table.
> I think that is kind of widget is useful when the map has many
> layers and
> many features displayed at the same time.
> I hope that it has clarified my idea
> Best regards
> Paul Spencer-2 wrote:
>> Hi Rodolfo,
>> unfortunately the Jx.Tree code is not designed to support content
>> that
>> is not a Jx.TreeFolder or Jx.TreeItem.  This is an interesting idea,
>> however.  Can you explain your use case?  I'm not promising that Jx
>> will be able to do it, but I would like to know why you want to do
>> it :)
>> Cheers
>> Paul
>> On 29-Aug-08, at 5:15 PM, Rodolfo Moreno wrote:
>>> Hi Paul,
>>> excuse my rudeness for writing to you straight, but I know you are a
>>> seasoned developer in Jx.
>>> I want to show a HTML table after doing click to a Jx.TreeFolder
>>> /* add a folder to the tree */
>>>   var folder = new Jx.TreeFolder({label: 'My Folder'});
>>>   tree.append(folder);
>>> /* put an item into the folder */
>>> var item = new Jx.TreeItem({label: 'item ' + i});
>>> folder.append(item);
>>> This is a sample that I found in zip file of fusion. It shows how
>>> put an
>>> item as a text into folder,
>>> but I would like to append a HTML table into folder, is it possible?
>>> Thanks in advance
>>> Rodolfo Moreno
>>> CivilEng
>>> View this message in context:
>>> http://n2.nabble.com/Add-HTML-table-inside-the-Jx.TreeFolder-object-tp793112p793112.html
>>> Sent from the Fusion Users mailing list archive at Nabble.com.
>>> fusion-users mailing list
>>> fusion-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fusion-users
>>    Paul Spencer
>>    Chief Technology Officer
>>    DM Solutions Group Inc
>>    http://www.dmsolutions.ca/
> Rodolfo Moreno
> CivilEng
> View this message in context: http://n2.nabble.com/Add-HTML-table-inside-the-Jx.TreeFolder-object-tp793112p796479.html
    Paul Spencer
More information about the fusion-users mailing list
