[fusion-users] Fusion enhancements
Paul Spencer pspencer at dmsolutions.ca
Thu Sep 11 08:39:22 EDT 2008
Hi Brad,
I don't plan to include a zoom to layer capability at this time,
although it is certainly possible to do it - all that is needed is a
way to compute the extent of a given layer.  In the existing Fusion,
this could be done it a couple of ways:
1) on start up:
   - modify LoadMap.php (compute a new property for each layer with
the extent and return it with the JSON object)
   - modify the appropriate Layer code in MapGuide and or MapServer to
store the extent as a property of the layer object
   - modify the Legend or add a new widget to zoom to the extent of
the current layer using this new property.
2) delayed:
the current layer that makes an asynchronous
     call to ...
   - ... a new script on the back end that computes the extents and
returns it to ...
   - ... the widget's callback handler which then zooms the map to the
appropriate extent
3) on start up, using existing metadata support (in the case of
MapServer layers):
   - add "layer_extent" "minx,miny,maxx,maxy" metadata to layers to
indicates the extent of the layer (you can use any key you want, as
long as it is the same in each step here)
   - modify ApplicationDefinition Map section and add a
<LayerMetadata>layer_extent</LayerMetadata> section to the Extension
element
   - - modify the Legend or add a new widget to zoom to the extent of
the current layer using this new metadata, accessible as
layer.getMetadata('layer_extent') in javascript.
Method 1) adds further overhead to the start up process, delaying
initial display of the map further, which is a pain that we are trying
to avoid.  Computing the extent of layers can be quite expensive and
potentially error prone.
Method 2) alleviates the start up problem but creates a small delay
when actually zooming
Method 3) is probably the best but only works for MapServer (since
there is no way to store arbitrary metadata in MapGuide AFAIK) and
requires that you pre-compute the extent of each layer.
In the next version of Fusion, we will be significantly streamlining
the startup process and method 1) won't be an option any more.
However, layer details will be retrieved asynchronously and extent
computation could be added at there, allowing the map to initially
load quickly while still having access to extra information we need to
build the legend and support some of the other layer-specific
operations.
Cheers
Paul
On 10-Sep-08, at 5:27 PM, BradM wrote:
> Is there any plan to create the ability to zoom to the extent of a
> map layer
> by selecting it in the legend?  Is there a plan to be able to link
> metadata
> to the map layers in the legend?  thanks
> View this message in context: http://www.nabble.com/Fusion-enhancements-tp19423473p19423473.html
> Sent from the Fusion Users mailing list archive at Nabble.com.
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
    Paul Spencer
    Chief Technology Officer
    DM Solutions Group Inc
    http://www.dmsolutions.ca/
More information about the fusion-users mailing list
