[fusion-users] PanQuery and pink backgrounds
Paul Deschamps pdeschamps at dmsolutions.ca
Thu Sep 11 21:21:27 EDT 2008
I would like to assist you on this:
1. Can we see your application? if not can you post your appdef. template
and supporting js code?
2. What revision are you using?
Cheers
Paul D.
On Thu, Sep 11, 2008 at 5:18 PM, Marc Pfister <mpfister at enplan.com> wrote:
> Paul Spencer [mailto:pspencer at dmsolutions.ca] wrote:
> > I haven't tried the panquery widget in a while.  The intention of the
> > widget was to have a dual mode widget that if you click and drag, it
> > pans and if you just click it does a query.  Looking at the code, it
> > doesn't appear to have anything that would cause it to make two
> > buttons.  Perhaps you have something unintentional in your
> > ApplicationDefinition (widget declared twice perhaps?).
> I noticed a few things and now have it working.
> 1. PanQuery.js requires Pan.js
> 2. I end up with 2 icons. Hmmmmm....
> 3. I set PanQuery.js and Pan.js to output a message to console when
> initializing.
> 4. I have a map that only has PanQuery in its ApplicationDefinition.xml
> 5. When it starts, I get messages that both Pan and PanQuery have
> initialized.
> 6. Perhaps it's adding a new OpenLayers control twice, once for each
> initialization.
> 7. Try commenting out the creation and adding of the control in either
> JS. No dice.
> 8. OK, try taking the event binding and the mouseup event method and
> adding into pan.js
> 9. Use query-fied pan.js
> 10. Success!
> So I'm not sure why exactly I couldn't get PanQuery.js to work, but it
> seems to have something to do with the require.
> Marc
> fusion-users mailing list
> fusion-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080911/269bf00a/attachment.html
More information about the fusion-users mailing list
