[fusion-users] PanQuery and pink backgrounds
Marc Pfister mpfister at enplan.com
Fri Sep 12 13:07:47 EDT 2008
My app is at:
http://209.20.81.81/fusion/templates/mapserver/corning/
Also, there's some weird behavior I just noticed with PanQuery - when
the map redraws, it draws a new querymap based off of a query on
location where you started your click and drag, even though it does not
make the selection there.
Note that my PanQuery is a modified pan.js, not panquery.js.
And, is it just me or is the selection highlight not drawn with the
antialiased renderer?
I'm using 1.1.0 RC1.
Marc
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Thursday, September 11, 2008 6:21 PM
To: Marc Pfister
Cc: Paul Spencer; fusion-users at lists.osgeo.org
Subject: Re: [fusion-users] PanQuery and pink backgrounds
I would like to assist you on this:
1. Can we see your application? if not can you post your appdef.
template and supporting js code?
2. What revision are you using?
Cheers
Paul D.
On Thu, Sep 11, 2008 at 5:18 PM, Marc Pfister <mpfister at enplan.com>
wrote:
Paul Spencer [mailto:pspencer at dmsolutions.ca] wrote:
> I haven't tried the panquery widget in a while.  The intention of the
> widget was to have a dual mode widget that if you click and drag, it
> pans and if you just click it does a query.  Looking at the code, it
> doesn't appear to have anything that would cause it to make two
> buttons.  Perhaps you have something unintentional in your
> ApplicationDefinition (widget declared twice perhaps?).
I noticed a few things and now have it working.
1. PanQuery.js requires Pan.js
2. I end up with 2 icons. Hmmmmm....
3. I set PanQuery.js and Pan.js to output a message to console when
initializing.
4. I have a map that only has PanQuery in its ApplicationDefinition.xml
5. When it starts, I get messages that both Pan and PanQuery have
initialized.
6. Perhaps it's adding a new OpenLayers control twice, once for each
initialization.
7. Try commenting out the creation and adding of the control in either
JS. No dice.
8. OK, try taking the event binding and the mouseup event method and
adding into pan.js
9. Use query-fied pan.js
10. Success!
So I'm not sure why exactly I couldn't get PanQuery.js to work, but it
seems to have something to do with the require.
Marc
fusion-users mailing list
http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080912/57cfce95/attachment.html
More information about the fusion-users mailing list
