[fusion-users] PanQuery and pink backgrounds
Paul Deschamps pdeschamps at dmsolutions.ca
Fri Sep 12 14:15:50 EDT 2008
I would be willing to assist you on getting the panquery widget to work.
Why are you using a hacked version of pan? when panquery is there?
heres an example for panquery in appDef
<!-- CONTAINER-->
      <Container>
          <Name>toolbar</Name>
          <Type>Toolbar</Type>
          <Position>left</Position>
          <Item>
              <Function>Widget</Function>
              <Widget>FitToWindow</Widget>
          </Item>
          <Item>
              <Widget>ZoomIn</Widget>
          </Item>
          <Item>
              <Widget>ZoomOut</Widget>
          </Item>
          <Item>
              <Widget>PanQuery</Widget>
          </Item>
      </Container>
    <Widget>
        <Name>PanQuery</Name>
        <Type>PanQuery</Type>
        <Description>Click or click and drag to select
features</Description>
      <Extension>
            <SelectionType>INTERSECTS</SelectionType>
            <Tolerance>25</Tolerance>
            <QueryActiveLayer>false</QueryActiveLayer>
      </Extension>
      <ImageUrl>images/icons/pan.png</ImageUrl>
      <Tooltip>Click or click and drag to select features</Tooltip>
    </Widget>
also if you do not want it to have a "button" for it at all you can add this
to your fusion initialized function and set it active
function onInitialize() {
    var map = Fusion.getMapById('mapArea');
    // activate PanQuery
    var panWidget = Fusion.getWidgetById('PanQuery');
    map.activateWidget(panWidget);
If you want a clue on the "wierd behaviour" it is your map tips fired event
that causes the focus to be lost.  That is causing the selection to be
triggered when you pan.
Cheers
Paul D.
On Fri, Sep 12, 2008 at 1:07 PM, Marc Pfister <mpfister at enplan.com> wrote:
>  My app is at:
> http://209.20.81.81/fusion/templates/mapserver/corning/
> Also, there's some weird behavior I just noticed with PanQuery – when the
> map redraws, it draws a new querymap based off of a query on location where
> you started your click and drag, even though it does not make the selection
> there.
> Note that my PanQuery is a modified pan.js, not panquery.js.
> And, is it just me or is the selection highlight not drawn with the
> antialiased renderer?
> I'm using 1.1.0 RC1.
> Marc
> *From:* pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] *On Behalf Of *Paul
> Deschamps
> *Sent:* Thursday, September 11, 2008 6:21 PM
> *To:* Marc Pfister
> *Cc:* Paul Spencer; fusion-users at lists.osgeo.org
> *Subject:* Re: [fusion-users] PanQuery and pink backgrounds
> I would like to assist you on this:
> 1. Can we see your application? if not can you post your appdef. template
> and supporting js code?
> 2. What revision are you using?
> Cheers
> Paul D.
> On Thu, Sep 11, 2008 at 5:18 PM, Marc Pfister <mpfister at enplan.com> wrote:
> Paul Spencer [mailto:pspencer at dmsolutions.ca] wrote:
> > I haven't tried the panquery widget in a while.  The intention of the
> > widget was to have a dual mode widget that if you click and drag, it
> > pans and if you just click it does a query.  Looking at the code, it
> > doesn't appear to have anything that would cause it to make two
> > buttons.  Perhaps you have something unintentional in your
> > ApplicationDefinition (widget declared twice perhaps?).
> I noticed a few things and now have it working.
> 1. PanQuery.js requires Pan.js
> 2. I end up with 2 icons. Hmmmmm....
> 3. I set PanQuery.js and Pan.js to output a message to console when
> initializing.
> 4. I have a map that only has PanQuery in its ApplicationDefinition.xml
> 5. When it starts, I get messages that both Pan and PanQuery have
> initialized.
> 6. Perhaps it's adding a new OpenLayers control twice, once for each
> initialization.
> 7. Try commenting out the creation and adding of the control in either
> JS. No dice.
> 8. OK, try taking the event binding and the mouseup event method and
> adding into pan.js
> 9. Use query-fied pan.js
> 10. Success!
> So I'm not sure why exactly I couldn't get PanQuery.js to work, but it
> seems to have something to do with the require.
> Marc
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080912/ce5f634a/attachment.html
More information about the fusion-users mailing list
