[fusion-users] PanQuery and pink backgrounds
Paul Deschamps pdeschamps at dmsolutions.ca
Fri Sep 12 16:00:23 EDT 2008
My comments are within the original email below: adding this back into the
list.
On Fri, Sep 12, 2008 at 2:26 PM, Marc Pfister <mpfister at enplan.com> wrote:
>  > Why are you using a hacked version of pan? when panquery is there?
> I'm using the hacked version of pan because when I try to use panquery, I
> get two of the pan icons, one disabled and one enabled but not selectable.
> However if I just drop the onmouseup select method and event binding from
> panquery.js into pan.js, then it works as it is supposed to.
You should not have this issue if you were to revert it to the the panquery
widget i can tell you why this is happening.
> > If you want a clue on the "wierd behaviour" it is your map tips fired
> event that causes the focus to be lost.  That is causing the selection to be
> triggered when you pan
> Well shoot. That's going to be a problem. I suppose I could make a clone of
> selection.php just for maptips that returns the same thing but doesn't
> trigger a selection event?
The other thing to note is the maptip is actually triggering a "QUERY /
SELECTION" to get the maptip and thus the selection has changed. You can see
the correct behavior if you quickly drag pan it does not get a chance to
fire maptips and then change the selection.
What you need to do is basically disable the maptips widget when the pan
widget is active.
Essentially in looking into this further it is the maptip div itself that is
the losing focus issue. when you mouse moves over that div you loose focus
on the map Window causing the pan to fire.
> Thanks for your help,
> Marc
Cheers
Paul D.
> *From:* pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] *On Behalf Of *Paul
> Deschamps
> *Sent:* Friday, September 12, 2008 11:16 AM
> *To:* Marc Pfister
> *Cc:* Paul Spencer; fusion-users at lists.osgeo.org
> *Subject:* Re: [fusion-users] PanQuery and pink backgrounds
> I would be willing to assist you on getting the panquery widget to work.
> heres an example for panquery in appDef
> <!-- CONTAINER-->
>       <Container>
>           <Name>toolbar</Name>
>           <Type>Toolbar</Type>
>           <Position>left</Position>
>           <Item>
>               <Function>Widget</Function>
>               <Widget>FitToWindow</Widget>
>           </Item>
>           <Item>
>               <Widget>ZoomIn</Widget>
>           </Item>
>           <Item>
>               <Widget>ZoomOut</Widget>
>           </Item>
>           <Item>
>               <Widget>PanQuery</Widget>
>           </Item>
>       </Container>
>     <Widget>
>         <Name>PanQuery</Name>
>         <Type>PanQuery</Type>
>         <Description>Click or click and drag to select
> features</Description>
>       <Extension>
>             <SelectionType>INTERSECTS</SelectionType>
>             <Tolerance>25</Tolerance>
>             <QueryActiveLayer>false</QueryActiveLayer>
>       </Extension>
>       <ImageUrl>images/icons/pan.png</ImageUrl>
>       <Tooltip>Click or click and drag to select features</Tooltip>
>     </Widget>
> also if you do not want it to have a "button" for it at all you can add
> this to your fusion initialized function and set it active
> function onInitialize() {
>     var map = Fusion.getMapById('mapArea');
>     // activate PanQuery
>     var panWidget = Fusion.getWidgetById('PanQuery');
>     map.activateWidget(panWidget);
> If you want a clue on the "wierd behaviour" it is your map tips fired event
> triggered when you pan.
> Cheers
> Paul D.
> On Fri, Sep 12, 2008 at 1:07 PM, Marc Pfister <mpfister at enplan.com> wrote:
> My app is at:
> http://209.20.81.81/fusion/templates/mapserver/corning/
> Also, there's some weird behavior I just noticed with PanQuery – when the
> map redraws, it draws a new querymap based off of a query on location where
> you started your click and drag, even though it does not make the selection
> there.
> Note that my PanQuery is a modified pan.js, not panquery.js.
> And, is it just me or is the selection highlight not drawn with the
> antialiased renderer?
> I'm using 1.1.0 RC1.
> Marc
> Deschamps
> *Sent:* Thursday, September 11, 2008 6:21 PM
> *To:* Marc Pfister
> I would like to assist you on this:
> 1. Can we see your application? if not can you post your appdef. template
> and supporting js code?
> 2. What revision are you using?
> Cheers
> Paul D.
> On Thu, Sep 11, 2008 at 5:18 PM, Marc Pfister <mpfister at enplan.com> wrote:
> Paul Spencer [mailto:pspencer at dmsolutions.ca] wrote:
> > I haven't tried the panquery widget in a while.  The intention of the
> > widget was to have a dual mode widget that if you click and drag, it
> > pans and if you just click it does a query.  Looking at the code, it
> > doesn't appear to have anything that would cause it to make two
> > buttons.  Perhaps you have something unintentional in your
> > ApplicationDefinition (widget declared twice perhaps?).
> I noticed a few things and now have it working.
> 1. PanQuery.js requires Pan.js
> 2. I end up with 2 icons. Hmmmmm....
> 3. I set PanQuery.js and Pan.js to output a message to console when
> initializing.
> 4. I have a map that only has PanQuery in its ApplicationDefinition.xml
> 5. When it starts, I get messages that both Pan and PanQuery have
> initialized.
> 6. Perhaps it's adding a new OpenLayers control twice, once for each
> initialization.
> 7. Try commenting out the creation and adding of the control in either
> JS. No dice.
> 8. OK, try taking the event binding and the mouseup event method and
> adding into pan.js
> 9. Use query-fied pan.js
> 10. Success!
> So I'm not sure why exactly I couldn't get PanQuery.js to work, but it
> seems to have something to do with the require.
> Marc
> fusion-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080912/76ea26d5/attachment-0001.html
More information about the fusion-users mailing list
