[fusion-users] PanQuery and pink backgrounds
Marc Pfister mpfister at enplan.com
Fri Sep 12 16:36:54 EDT 2008
> You should not have this issue if you were to revert it to the the
panquery widget i can tell you why this is happening.
Here's a version set to the PanQuery widget right now:
http://209.20.81.81/fusion/templates/mapserver/panquery
<Item xsi:type="WidgetItemType">
<Function>Widget</Function>
<Widget>PanTool</Widget>
</Item>
And
<Widget xsi:type="UiWidgetType">
<Name>PanTool</Name>
<Type>PanQuery</Type>
<StatusItem>Drag the map to pan.</StatusItem>
<ImageUrl>images/icons/pan.png</ImageUrl>
<ImageClass/>
<Tooltip>Pan mode</Tooltip>
<Label/>
<Disabled/>
</Widget>
>The other thing to note is the maptip is actually triggering a "QUERY /
SELECTION" to get the maptip and thus the selection has changed. You can
see the correct
>behavior if you quickly drag pan it does not get a chance to fire
maptips and then change the selection.
>What you need to do is basically disable the maptips widget when the
pan widget is active.
I need the maptips to be always be on, and it seems to break every UI
convention of a tooltip to have it only work some of the time.
So in order to fix this, is it possible to query information without
changing the selection? Alternately, could one store the current
selection, and have maptips revert back to that selection after it does
its query/selection thing?
Marc
From: pdescham49 at gmail.com [mailto:pdescham49 at gmail.com] On Behalf Of
Paul Deschamps
Sent: Friday, September 12, 2008 1:00 PM
To: Marc Pfister; fusion-users
Subject: Re: [fusion-users] PanQuery and pink backgrounds
My comments are within the original email below: adding this back into
the list.
On Fri, Sep 12, 2008 at 2:26 PM, Marc Pfister <mpfister at enplan.com>
wrote:
> Why are you using a hacked version of pan? when panquery is there?
I'm using the hacked version of pan because when I try to use panquery,
I get two of the pan icons, one disabled and one enabled but not
selectable. However if I just drop the onmouseup select method and event
binding from panquery.js into pan.js, then it works as it is supposed
to.
	> If you want a clue on the "wierd behaviour" it is your map
tips fired event that causes the focus to be lost.  That is causing the
selection to be triggered when you pan
	Well shoot. That's going to be a problem. I suppose I could make
a clone of selection.php just for maptips that returns the same thing
but doesn't trigger a selection event?
see the correct behavior if you quickly drag pan it does not get a
chance to fire maptips and then change the selection.
What you need to do is basically disable the maptips widget when the pan
widget is active.
Essentially in looking into this further it is the maptip div itself
that is the losing focus issue. when you mouse moves over that div you
loose focus on the map Window causing the pan to fire.
	Thanks for your help,
	Marc
Cheers
Paul D.
Behalf Of Paul Deschamps
	Sent: Friday, September 12, 2008 11:16 AM
	To: Marc Pfister
	Cc: Paul Spencer; fusion-users at lists.osgeo.org
	I would be willing to assist you on getting the panquery widget
to work.
there?
	heres an example for panquery in appDef
	<!-- CONTAINER-->
	      <Container>
	          <Name>toolbar</Name>
	          <Type>Toolbar</Type>
	          <Position>left</Position>
	          <Item>
	              <Widget>FitToWindow</Widget>
	          </Item>
	          <Item>
	              <Widget>ZoomIn</Widget>
	          </Item>
	          <Item>
	              <Widget>ZoomOut</Widget>
	          </Item>
	          <Item>
	              <Widget>PanQuery</Widget>
	          </Item>
	      </Container>
	    <Widget>
	        <Name>PanQuery</Name>
	        <Description>Click or click and drag to select
features</Description>
	      <Extension>
	            <SelectionType>INTERSECTS</SelectionType>
	            <Tolerance>25</Tolerance>
	            <QueryActiveLayer>false</QueryActiveLayer>
	      </Extension>
	      <Tooltip>Click or click and drag to select
features</Tooltip>
	    </Widget>
	also if you do not want it to have a "button" for it at all you
can add this to your fusion initialized function and set it active
	function onInitialize() {
	    var map = Fusion.getMapById('mapArea');
	    // activate PanQuery
	    var panWidget = Fusion.getWidgetById('PanQuery');
	    map.activateWidget(panWidget);
	If you want a clue on the "wierd behaviour" it is your map tips
selection to be triggered when you pan.
	Cheers
	Paul D.
	On Fri, Sep 12, 2008 at 1:07 PM, Marc Pfister
<mpfister at enplan.com> wrote:
	My app is at:
	http://209.20.81.81/fusion/templates/mapserver/corning/
	Also, there's some weird behavior I just noticed with PanQuery -
when the map redraws, it draws a new querymap based off of a query on
location where you started your click and drag, even though it does not
make the selection there.
	Note that my PanQuery is a modified pan.js, not panquery.js.
	And, is it just me or is the selection highlight not drawn with
the antialiased renderer?
	I'm using 1.1.0 RC1.
	Marc
	Sent: Thursday, September 11, 2008 6:21 PM
	To: Marc Pfister
	I would like to assist you on this:
	1. Can we see your application? if not can you post your appdef.
template and supporting js code?
	2. What revision are you using?
	Cheers
	Paul D.
	On Thu, Sep 11, 2008 at 5:18 PM, Marc Pfister
	Paul Spencer [mailto:pspencer at dmsolutions.ca] wrote:
	> I haven't tried the panquery widget in a while.  The intention
of the
	> widget was to have a dual mode widget that if you click and
drag, it
	> pans and if you just click it does a query.  Looking at the
code, it
	> doesn't appear to have anything that would cause it to make
two
	> buttons.  Perhaps you have something unintentional in your
	> ApplicationDefinition (widget declared twice perhaps?).
	I noticed a few things and now have it working.
	1. PanQuery.js requires Pan.js
	2. I end up with 2 icons. Hmmmmm....
	3. I set PanQuery.js and Pan.js to output a message to console
when
	initializing.
	4. I have a map that only has PanQuery in its
ApplicationDefinition.xml
	5. When it starts, I get messages that both Pan and PanQuery
have
	initialized.
	6. Perhaps it's adding a new OpenLayers control twice, once for
each
	initialization.
	7. Try commenting out the creation and adding of the control in
either
	JS. No dice.
	8. OK, try taking the event binding and the mouseup event method
and
	adding into pan.js
	9. Use query-fied pan.js
	10. Success!
	So I'm not sure why exactly I couldn't get PanQuery.js to work,
but it
	seems to have something to do with the require.
	Marc
	fusion-users mailing list
	http://lists.osgeo.org/mailman/listinfo/fusion-users
URL: http://lists.osgeo.org/pipermail/fusion-users/attachments/20080912/b5b43fec/attachment-0001.html
More information about the fusion-users mailing list
