[fusion-users] PanQuery and pink backgrounds
Marc Pfister mpfister at enplan.com
Mon Sep 15 13:58:50 EDT 2008
Paul Deschamps [mailto:pdescham49 at gmail.com] wrote:
>Your widget is a good basis thus far. Here's one method you can do to
preform the query:
>call a separate php script in the widget and in that script open up the
mapfile then do
>a queryByRect and return the results in json.
OK, great - I'll whip that up and see what happens.
>You can also add extension parameters in your appdef so you know what
layer(s) you want to display.
>The parsed applicationDef widget extentsion data is located in the
widgetTag.extension object.
I already have that coded up but it needs some testing.
Thanks again for your help,
Marc
More information about the fusion-users mailing list
